Author Topic: Wing mirror  (Read 5757 times)
Offline Deddi
  • 2016 GTi 3 door DSG
Wing mirror
« on: 26 April 2024, 23:31 »
Hi all
For some reason, my passenger wing mirror has stopped 'dipping' when car is put in reverse. The mirror works and adjusts perfectly in all directions when I use the knob on the door and they fold in fine.
I have checked the setting in the car settings on the infotainment screen and it is 'ticked' where it should be in the menu.
Any ideas what could be wrong, is there a way of resetting the mirrors somehow?
Thanks
2016 White GTi DSG 3 door
Offline JB73
Re: Wing mirror
« Reply #1 on: 27 April 2024, 00:10 »
Do you still have the mirror adjustment knob pointing towards the passenger mirror?
Offline Deddi
Re: Wing mirror
« Reply #2 on: 27 April 2024, 07:47 »
JB73 - Yes it is, I forgot to mention that!
Offline Guzzle
Re: Wing mirror
« Reply #3 on: 27 April 2024, 08:48 »
Have you tried manually adjusting the left hand mirror to your preferred reversing position when reverse is engaged?
If you do the above then disengage reverse and switch off the engine it should be fixed the next time you reverse.
Just make sure the box is ticked in the infotainment and left hand mirror is selected on the drivers door adjustment.
7.5 GTD
Offline Deddi
Re: Wing mirror
« Reply #4 on: 27 April 2024, 17:27 »
Thanks Guzzie, I'll try that when it stops raining!
Offline Deddi
Re: Wing mirror
« Reply #5 on: 29 April 2024, 18:14 »
Well I tried Guzzle's idea and the mirror dipped when I put it in reverse. Unfortunately, it wouldn't go back up to its normal position - it stayed in the dipped position until I adjusted it manually.
Any suggestions please?
Offline SRGTD
Re: Wing mirror
« Reply #6 on: 29 April 2024, 18:26 »
Did you try driving forward with the door mirror glass in the dipped position? It should return to the normal (non-dipped) position when you drove forward and reach a speed of somewhere between 5-10 mph (can’t remember the exact speed).
Gone but not forgotten;
2016 Polo GTI; Blue Silk
Offline Deddi
Re: Wing mirror
« Reply #7 on: 29 April 2024, 20:48 »
Thanks SRGTD. No I didn't do that, I'll try tomorrow
Offline Deddi
Re: Wing mirror
« Reply #8 on: 30 April 2024, 21:35 »
Thanks very much for the replies and suggestions, my wing mirror now dips when in reverse and returns to normal position when I go forward - great result!
