Author Topic: Axle back exhaust mk7  (Read 8219 times)
Offline Henners
« on: 24 April 2024, 18:11 »
Hi, first time posting. Found similar posts when searching but nothing specific..
I have a MK7 Golf GTI PP DSG 2016. I bent my exhaust pipe while doing a rather enthusiastic three point turn. Brilliant. After getting my mechanic to look at it, he says the rear muffler and pipes need replacing. I believe this is called an Axle Back exhaust modification.  He phoned around and it looks like a stock GTI muffler and pipes are around the £600 mark, which isn't far off a sports exhaust. So then I got thinking I might as well go for something which sounds a bit better.
I've heard of Milltek, Remus and a few others, or there is a Clubsport S muffler. I'm looking for a sportier more entertaining exhaust note but mainly while getting on it at higher revs, as opposed to loud all the time. I also don't want droning on the motorway or to annoy the neighbours with aggressive loud cold starts early in the morning. Aside from sitting in each setup in person, can anyone recommend which might be my best option forward, while trying to keep as close as possible to the £600 mark of stock?
I plan to go Revo stage 1 at some point so it needs to be future proof for that.
From my research it seems a Clubsport S muffler box and pipes would do the job - a better noise when accelerating hard, a bit more idle burble, but not a full expensive cat back system or res delete. As I understand, an axleback replacement does not affect the flow of gases enough to require any form of ECU remap. Does this all sound about right or am I wildly off?
Thanks
H
Offline rowlers
  • I'm back - MK7 GTI
Re: Axle back exhaust mk7
« Reply #1 on: 24 April 2024, 19:05 »
Res delete (anti drone, if required) and a clubsport s back box would be my first choice, or pick up a second hand standard back.
Offline Peter_booker2003
« Reply #2 on: 24 April 2024, 20:46 »
Having gone down a similar route recently on my TCR I was looking for something OEM+ and after fitting a Remus I have been really happy with the noise when you a both on it and also just cruising. I loved the stock sound but wanted something louder when I was really enjoying the car.
I have just got back from a 200 mile trip down the motorway and the Remus Is no louder than the stock exhaust, and only comes alive when you are on it. A perfect mix if you ask me as a golf needs to be classless for every use.
I have been looking for an Akrapovic Exhaust for ages and have now found one so will be taking the Remus off and selling it. I wanted £700 but would take £600 if that was of interest. It is on a MK7.5 with an OPF so not sure how that would fit but I think the non-Opf downpipe is just longer so would fit the same I think? Sure someone on here will be able to confirm.
Offline Finglonga
« Reply #3 on: 24 April 2024, 22:10 »
Also used to have a Remus Axle Back but the quad pipe version and it sounded much better than stock. But if down the line you do a res delete it will drone unless you get an Helmholtz anti drone res delete, even then you will notice some at 60-70mph and it will be significantly louder than stock also but much deeper and crisper.
Offline ProtoCulture
« Reply #4 on: 27 April 2024, 20:52 »
You are pretty much me when it comes to what you want/wanted at the time.
I can recommend the CSS backbox. Its not much louder than stock when just driving normally, but once you get on it, it comes alive.
Check my post history.
2016 Tornado Red GTI PP, DSG, Pro Nav, Dynaudio, Park Assist & Camera.
Mods: Revo Stage 1 ECU & TCU remap. Racingline R600 with Inlet pipe, turbo elbow and muffler delete. Clubsport S backbox. Eibach lowering springs. VBT Hooked discs and Racingline RP700 pads, braided lines and RBF660 fluid.
Protrack One wheels (18x8, ET45) 12mm spacer on rear.
Geo by Swift Performance
Offline willni
« Reply #5 on: 28 April 2024, 10:12 »
It’s fairly evident from this thread we’re all of the same opinion when it comes to the exhaust note, tastefully loud but not obnoxious. As well as if you read through the other posts on the forum about which exhaust the CSS, TCR or Remus systems are a favourite across many of the forum members.
Much like Peter, I have a Remus system and experience no drone but I do have a gpf as well. I think it’s the perfect level of sportiness without being obnoxious like many if the millteks I’ve heard
Offline Henners
« Reply #6 on: 16 June 2024, 00:17 »
Thanks for all your replies. In the end I went with a CSS backbox. I cannot really notice any difference to stock. A bit underwhelming but I suppose for a proper exhaust note you need a full catback system. If anyone else is looking for some more noise above stock, I would suggest something more than just the CSS backbox. Next options are a res delete or new downpipe
Offline oryx3dr
« Reply #7 on: 16 June 2024, 08:14 »
The CSS back box and res delete combo is truly fantastic. I ran this on my previous Mk7 GTI.
Current - 2020 Black Golf GTI Performance Pack DSG, Sunroof, Dynaudio, Climate Windscreen, Brescia's
Sold - 2017 MK7 Oryx White 3dr GTI
Sold - 2019 Up GTI
Offline Henners
« Reply #8 on: 21 June 2024, 11:29 »
Did you get drone on the motorway?
