Author Topic: Help Urgent!!!!  (Read 3670 times)
Offline GTI16vGaz
  • New car will be displayed soon.
Help Urgent!!!!
« on: 29 October 2003, 08:41 »
Last Friday i was drving through sheffield and i come to some lights and Jag xj8 pulled up next to me, so as you would i thought i would race it from the lights, my car did pull away frist  ;D but then my oil light started to flash and my engine was tapping really loud, louder than usual. (then the Jag went flying past)
So i stopped on the parkway with my hazards on checking to see if any oil was leaking and it wasn't. I then phoned a mate who nows a lot more than me n he said my engine was ready for blowing up.... >:( so i was well pissed off at this stage.
I had a 50mile trip so i thought F?$& it so i did the trip and the oil light stopped and the ticking stopped.
Could this be the oil pump failing to pump oil into my engine, this may have casued the ticking (tappping) due to no oil getting pumped through.
As today the car is fine but its on my mind all the time that somets going to go wrong.
Any advice would be great.
Thanksl Lads,  ;)
Gaz
Offline GTI16vGaz
Re:Help Urgent!!!!
« Reply #1 on: 29 October 2003, 09:18 »
Come on, some1 has got to have experienced this?
Cheers,   ;)
Gaz
Offline Ant
Re:Help Urgent!!!!
« Reply #2 on: 29 October 2003, 11:30 »
What oil do you use and what's your car's mileage?
Offline GTI16vGaz
Re:Help Urgent!!!!
« Reply #3 on: 29 October 2003, 13:24 »
I think its something like 15/40 can't remember the make.
The cars done 140000..
Cheers,
Offline tinman
Re:Help Urgent!!!!
« Reply #4 on: 29 October 2003, 14:04 »
This sounds strange - but do you have enough oil in the engine?!
If you are low for instance, I know that going round a right hand bend will set it off.
If the dipstick doesn't give you a definitive answer, do an oil change at the weekend and measure how much oil comes out.
Tin
« Last Edit: 29 October 2003, 14:04 by tinman »
Offline GTI16vGaz
Re:Help Urgent!!!!
« Reply #5 on: 29 October 2003, 15:52 »
Tin
Cheers Tinman.. i think the oil level is fine but i'll check it when i get home.
I've already experienced the buzzing on the oil light when turning hard right.
thanks again
golfvr6
Re:Help Urgent!!!!
« Reply #6 on: 29 October 2003, 16:53 »
Get the oil pressure tested!
Offline GTI16vGaz
Re:Help Urgent!!!!
« Reply #7 on: 30 October 2003, 11:58 »
Ok will do if i new how to? do need some kind of special tool?
cheers
golfvr6
Re:Help Urgent!!!!
« Reply #8 on: 01 November 2003, 00:16 »
You need to take out one of the oil pressure switches and put a gauge in. Try any motor spares shop, they might do one.
Offline Dizzie
  • Make friends with your fast
Re:Help Urgent!!!!
« Reply #9 on: 01 November 2003, 16:20 »
I want an oil pressure gauge. I was told to get the reading you link it up to the bit stuck out the side of the block with a johnny on it. haven't done it yet due to lack of funds...  :'(
