Author Topic: Attention - New Rust Point - Front Arches Chassis  (Read 13559 times)
Offline Mikeyd1
Re: Attention - New Rust Point - Front Arches Chassis
« Reply #10 on: 22 March 2024, 20:54 »
Still very low .feel for ya mate, know likes seeing this stuff on our cars .  Let me know how u get on as I said when I pull my arches I’ll be checking mine . My mates Gti 2018 at the rear arches have quite a few of zinc inclusions as well so something to keep an eye out for .
2017 gti dsg white silver, 3door, dcc , Brescia alloys, pro Nav dvd ,dynaudio, dcc . Rear tints
Offline symonh2000
« Reply #11 on: 23 March 2024, 11:08 »
Our 2016 car has a fair bit of rust on things like the subframe, drive shafts and suspension arms which I will need to deal with.
My Mk4 Golf had many faults but even at 10+ years old it didn't suffer any rust problems on critical parts.
Golf GTI 7 PP
BMW M140i
Offline willni
« Reply #12 on: 23 March 2024, 12:26 »
Only difference is you can get a full new suspension for a mk4 for £400 to sort it if it did.
Offline clubsport
« Reply #13 on: 23 March 2024, 13:49 »
There is a Volkswizard video that covers potential rust issues on the Mark 7; https://www.youtube.com/watch?v=PxLU0b5fL5k
I did mine last summer on a very hot day, so that it was easy to spray the rust proofer.
Offline Mikeyd1
« Reply #14 on: 30 August 2024, 18:51 »
Started mine today what a chore . I too have a very minor slight abrasion
« Last Edit: 30 August 2024, 18:53 by Mikeyd1 »
Offline Mikeyd1
« Reply #15 on: 30 August 2024, 18:58 »
Galvanised surfaces can still corrode unfortunately, and abrasion can remove the zinc coating from the steel.
One side reacted fairly heavily to the rust neutraliser and the other had a much smaller reaction, I resprayed with graphene primer and put a bit of underseal over it for now, but will be going back later and adding better protection. Probably that helicopter tape Jace recommended.
I considered something like dynamat sound deadening but concern that the bituminous material could hold moisture.
Hi mate do you notice any real difference with the foam triangles removed I’m just deciding if to remove them or not? Thanks
Offline willni
« Reply #16 on: 31 August 2024, 07:15 »
Looks great, but I hate that you have a white silver gti, I want another white silver so badly  :grin:
With regard to the noise with the foam triangles removed, I've noticed no difference it's such a minor component in noise suppression I doubt anyone would ever notice.
« Last Edit: 31 August 2024, 07:18 by willni »
Offline Mikeyd1
« Reply #17 on: 31 August 2024, 07:19 »
Thanks mate . What did you do with your foam triangles ? I’m debating removing them or not . I don’t want loads of wind noise and checking where they sit I couldn’t see any problem with the paint. Cheers
Offline willni
« Reply #18 on: 31 August 2024, 07:25 »
I chucked mine into the bin  :smiley: If you're desperate to keep them you could chop 1-2 inches off the arch edge end and should be fine.
Offline Mikeyd1
« Reply #19 on: 31 August 2024, 09:08 »
Cheers mate did you experience any extra noise when they are removed.?? Thanks
« Last Edit: 31 August 2024, 15:07 by Mikeyd1 »
