Author Topic: Attention - New Rust Point - Front Arches Chassis  (Read 13563 times)
Offline willni
« on: 18 March 2024, 18:50 »
Folks,
Just letting you all know for those that keep cars for long periods of time. When I was removing the foam triangles under the front arches I noticed the following on the body:
The plastic arch liners are rubbing through the token amount of paint VW have sprayed on at the factory and leaving it as a bare metal exposed area on the body, and will undoubtably become a problem later on.
I'm currently repairing mine but not sure what to put over it once neutralised and resprayed, seam sealer?
Offline Jace
Re: Attention - New Rust Point - Front Arches Chassis
« Reply #1 on: 19 March 2024, 09:38 »
once sealed maybe something like Helicopter tape ?
2018 Golf R 7.5 Estate > Full Revo stg2 set up
Offline Adam T7
« Reply #2 on: 19 March 2024, 10:14 »
Aren’t (according to the brochure) body panels galvanised and (this is from my dim and distant past schooldays 45 years ago) a galvanised surface can ‘heal’ itself?
Offline coolhandluke123
« Reply #3 on: 19 March 2024, 11:25 »
Helicopter tape ?
After all the issues with the foam on the MK5 wheel arches you'd have thought VW might have learnt a lesson.
« Last Edit: 19 March 2024, 11:30 by coolhandluke123 »
Offline willni
« Reply #4 on: 19 March 2024, 11:40 »
Galvanised surfaces can still corrode unfortunately, and abrasion can remove the zinc coating from the steel.
One side reacted fairly heavily to the rust neutraliser and the other had a much smaller reaction, I resprayed with graphene primer and put a bit of underseal over it for now, but will be going back later and adding better protection. Probably that helicopter tape Jace recommended.
I considered something like dynamat sound deadening but concern that the bituminous material could hold moisture.
Offline Adam T7
« Reply #5 on: 19 March 2024, 12:54 »
I’ve used helicopter tape on my bike where the chain can potential hit the carbon fibre chain stays. Zero damage after 11 years and 100% water and oil resistant.
Offline Tractor Dave
« Reply #6 on: 19 March 2024, 13:17 »
Dinitrol 447 is very good.
Offline EB2019
« Reply #7 on: 19 March 2024, 20:51 »
Thanks for the info Willni, will keep an eye out for it.  :wink:
Offline Mikeyd1
« Reply #8 on: 21 March 2024, 20:47 »
what your mileage mate . I hate finding this sort of stuff on my pride and joy I’m also very fussy about my car . I’ll be checking mine soon as was planing to dynax under arches in late summer .
« Last Edit: 21 March 2024, 21:07 by Mikeyd1 »
2017 gti dsg white silver, 3door, dcc , Brescia alloys, pro Nav dvd ,dynaudio, dcc . Rear tints
Offline willni
« Reply #9 on: 22 March 2024, 18:52 »
I'm on 32k miles.
