Author Topic: Waterpump/thermostat housing leaking  (Read 7096 times)
Offline JamesR27
« on: 12 March 2024, 19:42 »
Hi,
I have just had my car Serviced and they noticed a water leak coming from the waterpump/thermostat housing. I have got the car booked in on the 26th which is the earliest I could get it in.
I keep checking the fluid levels and it’s staying at the max level and the only signs of a leak on the floor is the odd 5p size drip if that and not all the time.
In the mean time am I able to use the car as normal without damaging it?
The reason I ask is I could do with doing a 200 mile round trip this weekend.
Thanks in advance
Mk 8.5 Clubsport Pure White, Queenstown, DCC.
MK 7.5 R Pure White, Pretoria Silver, DCC, Rear Camera.
Gone - MK 7 GTI Carbon Grey, Rear Camera, Service Pack.
Gone - MK 6 GTI  Reflex Silver, Monza Shadows, RCD 510, Rear Camera, Bluetooth, Tyre Pressure Sensor, Xenons Convenience pack, Service Pack :)
Gone - MK 5 GTI Reflex Silver, Monza II 18's, Luxury Pack, Mulitchanger
Offline rowlers
  • I'm back - MK7 GTI
Re: Waterpump/thermostat housing leaking
« Reply #1 on: 12 March 2024, 21:37 »
I'd say you'd be fine, I drove mine for a few hundred miles until I could get the waterpump etc done.
Offline P6GTD
« Reply #2 on: 13 March 2024, 09:08 »
Likewise, identical diagnosis during service 4 wks ago.
My car goes in for replacement of these parts tomorrow.
Cost £950 is being met under All In plan.
You are safe to carry on driving.
If anything goes amiss, the car will warn you.
Carry On Driving (sounds like a Kenneth Williams movie).
Offline Finglonga
« Reply #3 on: 13 March 2024, 11:31 »
Drove mine for around a year with mine leaking, had to top up every week or so with about half a Litre of coolant. As long as you keep an eye on the levels you will be fine they do not suddenly fail and dump coolant.
Offline JamesR27
« Reply #4 on: 13 March 2024, 21:00 »
Thanks that’s what I was worried about it just fully leaking out and I do keep an eye on it so hopefully it will be ok.
Offline Finglonga
« Reply #5 on: 15 March 2024, 10:38 »
When you do get it done do not use a main dealer find a good independent as it will save you hundreds.
Offline P6GTD
« Reply #6 on: 16 March 2024, 09:56 »
Well, mine was done yesterday at the dealers. A job listed for around 4hrs took almost a complete day due to the faff of taking stuff apart and putting it together again. Apparently it turned out to be trickier than they had allowed for.
Fortunately I have All In package so a job quoted at £950 cost me nothing.
If the labour cost had been “open ended”, I suspect the entire job would have been more than £950.
Online davo245
« Reply #7 on: 21 March 2024, 07:20 »
Hi,
Thanks in advance
Yes be fine to use mine lost coolant for while before I had it changed under warranty.
Also make sure the dealer changes both not just thermostat housing or pump, most dealers will do but the useless one that did mine said we only change the stat housing as that is what's leaking but few months later it stated leaking again!
Pump this time!!
Mk6 GTI DSG
MK7.5 GTI performance DSG
Mk8 GTI
Online davo245
« Reply #8 on: 21 March 2024, 18:14 »
Hi,
Thanks in advance
If dealer says they only change either of the 2 not both try another dealer.
Mk6 GTI DSG
Mk8 GTI
