Author Topic: Wanted: Reifnitz or Pretoria Wheels  (Read 10054 times)
Offline pixelcellar
« on: 19 February 2024, 09:09 »
Just pulled the trigger on a TCR, want to add some Reifnitz wheels to it as opposed to the more common Pretoria's ideally.
Anyone got a set for sale? If it helps I have a pristine set of Belveder's coming off that could be part of a swap deal if that works?
« Last Edit: 24 February 2024, 16:29 by pixelcellar »
2024 - Current: 2019 Mk7.5 Golf GTi TCR 286bhp, 5dr, Pure Grey, 7spd DSG, 19" Oz Ultraleggera HLT Alloys, Park Assist, Dynamic Lane Assist/DLA, Side Assist, Rear View Camera
2020 - 2024: 2019 Mk7.5 Golf GTi Performance 245bhp, 3dr, Deep Black Pearl, 6spd Manual, 19" Brescia Alloys, Park Assist, Dynamic Lane Assist/DLA, Rear View Camera
2017 - 2020: 2017 Mk5 Polo GTi 190bhp, 3dr, Metallic Black, 6spd Manual, 17" Santiago Alloys
Offline pixelcellar
Re: Wanted: Reifnitz or Pretoria Wheels
« Reply #1 on: 24 February 2024, 16:29 »
Think I'll be happy with the Pretoria's but they need to be black not silver..... Anyone???
Offline willni
« Reply #2 on: 24 February 2024, 18:55 »
As much as I want your belvederes, you should actually drive on a set of 19s first before selling them.
There's a reason a few of us want the belvederes.
Offline pixelcellar
« Reply #3 on: 25 February 2024, 08:31 »
You reckon there's much of a difference? I've got 19's (Brescia's) on my non DCC car now, would it not feel the same for example?
Offline clubsport
« Reply #4 on: 25 February 2024, 08:59 »
You say you would be happy with the 19" Pretotias. if buying secondhand check them over carefully, the Pretoria in 19" don't seem quite so strong as the Brescia, I suggest this as you often see damaged and repaired examples for sale, no doubt caused by the state of UK roads.
If buying I would want to drive down the road with them on a car first, to see if they were straight under steering and braking.
I have not seen or read anything about the quality of the factory Reifnitz wheels thay are fairly new and possibly harder to find?
There may be a slight difference with 19" wheels on a non DCC equiped TCR as the springs are slightly stiffer over the regular Performance pack GTi, I understand.
You would need to try 19's to see if it suits you, I doubt it is a world away from your 19" Brescia experience. especially with new supple tyres and suitable tyre pressures.
« Reply #5 on: 25 February 2024, 09:30 »
Maybe try a set of spacers on the Belvederes to beef them out in the arches a bit?
If you weren’t so far away I’d have loaned you my old Reifnitz replicas to try for a while to see how you get on with 19’s back to back with the lightweight 18’s.
Personally if it was a daily driver I’d store the Belvederes and run a set of CM Wheels replicas which would be less likely to make you cry if you bent one on a huge pothole.
I ran a set of 19” Reifnitz reps for 3 years (26k) and they held up well despite some really badly potholed roads. The NSF took a bit of a slight outer rim bend on a massive fresh hole but not enough for the MOT tester to even mention it. I only expected them to last the first winter before changing them for something else but they looked good and stood up to rubbish roads well.
Offline pixelcellar
« Reply #6 on: 25 February 2024, 09:37 »
Cheers for the advice guys, think I’ll stick my Brescias on and see how they feel, if they feel ok then might go down the replica Reifnitz route, have seen a lot of Pretoria’s that are damaged, pristine sets are not cheap but even then you don’t know what state they have been in. If going the replica route I’ll probably get some Reifnitz clones and maybe get some genuine ones in the future; my brother has a Nurberg problem so is over there a few times a year so could get him to bring me some back cheaper than we can get them here…
« Reply #7 on: 25 February 2024, 09:42 »
… or you could go with him and try the TCR on the ‘ring!  :cool:
Offline pixelcellar
« Reply #8 on: 25 February 2024, 09:54 »
Oh hell no, heard too many horror stories and want my car to stay intact; I highly doubt it’ll ever see a track!!
Offline willni
« Reply #9 on: 25 February 2024, 10:20 »
I noticed a massive difference personally going from Brescias (and many other sets) to Belvederes, feels nicer in corners and much better suited to the roads I'm on at least, hence why I'm after another set.
