Author Topic: Cracked Headlight lens  (Read 3653 times)
Offline rowlers
  • I'm back - MK7 GTI
« on: 25 January 2024, 14:04 »
My DRL LED/Driver has failed on the drivers side.
Its going in to VW on Monday for investigation, but in the mean time I've notice that the lens is cracked too. Don't know if its coincidence, but I'm concerned that the dealer will blame the crack and refuse warranty.
Anyway, the thoughts of a new headlamp is quite disturbing, I'm looking at £500+ for a second hand one! If I can get the DRL back on and working, is it feasible to use some protection film on the headlight to keep it sealed until I can find a reasonably priced replacement?
Thoughts?
Offline Jace
Re: Cracked Headlight lens
« Reply #1 on: 26 January 2024, 09:55 »
Here you go, available single or pairs  :cool:
https://www.aliexpress.com/item/1005005885885980.html
2018 Golf R 7.5 Estate > Full Revo stg2 set up
Offline rowlers
« Reply #2 on: 26 January 2024, 11:19 »
Oh, Excellent! Are they easy to replace? Its not something I even knew was possible!
Offline Jace
« Reply #3 on: 26 January 2024, 15:54 »
I'm not sure, looking at the feedback images you'll need to heat up the sealant around the original lenses.
Have a search on Youtube, this is bound to be a few videos on how its done
Offline Adam T7
« Reply #4 on: 26 January 2024, 16:34 »
On a previous car owners website a few members hated the amber indicator section of the sealed light units and wanted to replace them with a clear section. They used to heat them up in an oven to melt the sealant, a bit to brave for me.
Offline rowlers
« Reply #5 on: 26 January 2024, 17:30 »
Thanks all, watched a couple of videos, looks straight forward, if a little hard work.
Its in at the dealer on Monday, so if they feck me off I'll have a go at changing the glass...
Offline rowlers
« Reply #6 on: 29 January 2024, 13:40 »
Looks like the warranty will cover the waterpump/thermostat, but won't cover the DRL. They reckon water has got into the DRL module from the cracked lens, £1400 to replace!  :grin: :grin: :grin:
Looks like I'm replacing the lens and module myself!  :undecided:
