Author Topic: About to buy - couple of questions  (Read 854 times)
Offline MrLou
« on: 21 October 2005, 20:07 »
Hi there,
After umming and ahhing I've decided to stump up and buy a Mk2 8v on an E plate.
Been to see it today and it looks in good nick.
The only 2 thing that worried me slightly was some rust around the rear towing eye and the fact that the water temp indicator wasn't working.
Everything else seemed straight, trip comp OK, very tidy inside and it went well too.
Should I worry about the rust and the water temp gauge?
Cheers!
Lou
Re: About to buy - couple of questions
« Reply #1 on: 21 October 2005, 21:51 »
rust round the towing eye isn't a prob, thats just the rear valance, nothing structural.  Just clean it up & spray, doen't have to be an amazing job as its not something you'll see.
I wouldn't worry about the water temp gauge not working either, probably an easy fix.  1st think pop the bonnet and check the plug to the black temp sensor, will have a brown & red/yellow wire.  Should be located in the plastic flange at the front of the block, where the radiator top hose goes to.
What you need to check is that the bottom hose is stone cold till the oil temp is arround 80 degrees, if it gets lukewarm straight away then it means the thermostat is stuck open/missing so might explain why the gauge isn't working.
