Author Topic: folding mirror query  (Read 19948 times)
Offline Redvtec
« on: 12 December 2023, 15:23 »
Hi I have folding mirrors on my car, I had to have the passenger window motor replaced. now the mirror on that side does not fold in and out, is it related? thanks
Offline joe6
Re: folding mirror query
« Reply #1 on: 12 December 2023, 18:06 »
Most likely related. Sounds like the control module in the door has not been reconnected correctly.
Offline Redvtec
« Reply #2 on: 12 December 2023, 19:20 »
Thanks for the reply? does the control module have to be reprogramed?
Offline JSYGTI
« Reply #3 on: 12 December 2023, 22:32 »
I'd be going back to whoever did the work on the window regulator. Hope you get it sorted soon though.
Offline joe6
« Reply #4 on: 13 December 2023, 08:54 »
Not necessary as settings will not have changed unless someone has been 'playing' with them.
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #5 on: 13 December 2023, 08:58 »
Have a look at the retrofit folding mirror thread a couple of threads down. It may have more info on if the motor is different for the folding mirror specs.
Current Garage:
35+ years of GTI ownership.
Offline Nino
  • Insta - F6UGA
« Reply #6 on: 15 December 2023, 00:38 »
It will be one of two things.
  • Replacement Module used was not the correct one
  • Replacement Module used was 2nd hand with different coding or needs to be coded to match your old one
Whoever did the replacement should have taken the coding reading from your previous module and copied it into your new one.
« Last Edit: 15 December 2023, 00:40 by Nino »
Current - MK6 GTi Edition 35 - Candy White - 3 door.
Offline Bluto
« Reply #7 on: 17 December 2023, 09:44 »
As has already been said, assuming the correct replacement window motor/controller module has been installed.  The replacement motor/controller unit may be missing the correct coding for your car - as @Nino has already mentioned.
I agree with @JYSGTI that I'd be going back to whomever you got to do the work in the first place.
Below may potentially help if you get stuck.  Via VCDS I've gone into the module on the driver's side door of my UK spec 2009 Mk6 GTI which has fold-in mirrors fitted from factory, and pulled its long coding config.
Small disclaimer: various revisions of controllers and later Mk6 GTIs may have different configuration settings or options to mine, so I'm not guaranteeing my config would work on your vehicle.  Plus if anyone does tinker with VCDS I can't emphasise enough backing up/saving your car's config before making any changes. e.g. do an autoscan and save it, make notes of any Software Coding values before making changes and take lots of screen shots!  So any changes can be reverted back if needed helping to avoid 'bricking' your car.
Anyway the config for the 42-Door Elect, Driver module on my vehicle is:
Byte 0
Byte 1
Byte 2
« Last Edit: 17 December 2023, 09:56 by Bluto »
Mk8 GTI Clubsport | Pure White | DCC | Black Estorils | HUD | a fair few options
Previous: Mk6 GTI | Candy White | Manual | DCC | Dynaudio | Cruise | Winter Pack | Lux Pack | Rear Camera & F/R Parking Sensors
Offline Nino
  • Insta - F6UGA
« Reply #8 on: 18 December 2023, 08:34 »
Byte 0
Byte 1
Byte 2
Bluto, I take it you have a 5 door?
Checked mine and I have:
0004918
0004919
Offline Bluto
« Reply #9 on: 19 December 2023, 08:23 »
0004918
0004919
Yes @Nino my Mk6 is a 5-door.  Good point I should've mentioned that.  :wink:
