Author Topic: What Coil Packs?  (Read 3885 times)
Offline willni
What Coil Packs?
« on: 25 November 2023, 14:12 »
So another coil pack has gone in my car, slight misfire and mpg reduced by 8mpg. So wondering if the aftermarket coil packs are any better as I know the VW one's hate being removed when doing spark plugs.
Hoping someone has some experience with this on OEM vs the likes of APR / Racingline or Audi upgrades?
Offline madstaff
Re: What Coil Packs?
« Reply #1 on: 25 November 2023, 15:01 »
A bit of dielectric/silicone grease in the plug boots helps when removing, especially if the engine is warm.
If the coil pack detaches from the rubber boot a quick squirt of WD40 down the boot and a quick blast of compressed air normally shoots the boot off.
The boots are available to buy separately.
I can't see how the "upgraded" coil packs can be any better than OEM IMO. Snake oil??
They can be an absolute pain at times to remove though.
Offline willni
« Reply #2 on: 25 November 2023, 19:29 »
Touch wood I have yet to encounter the issues you've had, just coils going.
Upgraded coils are most likely snake oil but in Black Friday they're a good bit cheaper than OEM ones, was more looking at durability than an actual upgrade.
I was told that they they should be changed in sets due to electric transfer but seems unnecessary in my opinion, but hoping someone could confirm or debunk this?
Offline madstaff
« Reply #3 on: 26 November 2023, 09:40 »
That was out my daughters Polo BlueGT.
I suppose good practice is to replace as a set, but you give the option to customers 1 for £40 or the set for £160 you can bet the majority just have just the faulty one replaced.
