Author Topic: DSG Service  (Read 31197 times)
Offline Nilz
DSG Service
« on: 08 November 2023, 00:13 »
Hi Guys
Hope everyone here is good?
I have a 7.5 PP DSG and wanted to know if it needs a gearbox service.  I just had the brake pads done on the car and an oil and filter service as it hit 35k, so wanted to know if this is required on it and what actually needs doing.
Any help and advice would be much appreciated.
Thanks
Nilz
Offline madstaff
Re: DSG Service
« Reply #1 on: 08 November 2023, 08:41 »
According to the maintainence schedule the DSG requires an oil/filter change either -
DSG 0D9 gearbox code - replace oil and filter every 40,000 miles or
DSG 0CG gearbox code - replace oil every 80,000 miles
Relatively straightforward to do, need some kind of diagnostics to monitor gearbox temp whilst refilling though.
Offline Adam T7
Re: DSG Service
« Reply #2 on: 08 November 2023, 09:51 »
I had mine serviced at 3 years with only 13k on the clock and will have it done next year (when 6 years old) with about 27k on the clock, ISTR it cost £160 at local Independent.
Probably a bit OTT, but I plan to keep the car for a long time, service is relatively cheap, new DSG boxes not so cheap.
Offline willni
Re: DSG Service
« Reply #3 on: 08 November 2023, 10:49 »
A friends DSG mechatronics went on his 7.5 GTD and cost £4k, luckily he had the extended warranty and was fully covered But it would equal 25 services of your DSG box.
Offline Nilz
Re: DSG Service
« Reply #4 on: 12 December 2023, 15:10 »
Thanks for the responses guys, I forgot I put the question up actually!!
Is there an easy way to identify which gearbox I have?
Offline jh_97
Re: DSG Service
« Reply #5 on: 09 January 2024, 08:50 »
Bumping this up as I have the same question... Service due probably in the next month for me, will be on ~34.5k miles at that point. I've owned since 24.5k miles last July.
2018 GTI PP DSG, Pure White, graphite Sevilles, Art Velours
Offline SRGTD
Re: DSG Service
« Reply #6 on: 09 January 2024, 09:09 »
VW’s recommended service intervals for the seven speed DSG (DQ381) service interval is 80k miles and the six speed DQ250 is 40k miles - see link below. I think the service intervals are solely mileage based rather than the sooner of x miles or y months, although I seem to remember that the DQ250 used to be the sooner of 40k miles or 48 months(?). However, some owners on various VAG forums still tend to get their DSG serviced at 48 months, whether it’s the DQ381 or DQ250.
My car (Polo GTI+ with 6 speed DQ250 DSG) will be 4 years old in September and will have only covered around 17k - 18k miles by that time, but I’ll probably still get the DSG service done; I’m an advocate of proactive rather than reactive maintenance, and prevention is better (and less expensive) than cure.
https://tps.trade/insider/dsg-servicing
Gone but not forgotten;
2016 Polo GTI; Blue Silk
Offline Nilz
Re: DSG Service
« Reply #7 on: 09 January 2024, 11:37 »
Thanks for all of the responses guys, looks like I have the DQ381 - 0GC gearbox and its saying 80k fluid only.  As the car is almost 6 years old and on about 40k, I will get the oil changed at the next service to be on the safe side.
As mentioned above, being proactive in this scenario will be a lot more beneficial than being reactive!!
I have already experienced a mechatronic going on a previous car, luckily within warranty so they covered it, but costs were still high.
Offline skippy
Re: DSG Service
« Reply #8 on: 01 July 2026, 21:34 »
Hello All,
Just picking up on this old thread. DSG Service, my MK7.5 GTI (2020) only has 18K miles, but the service interval for this spec of DSG is 80K miles! As I only do 3K miles per year on average and intend to keep the car a long time, I am considering getting the fluid changed. At this rate, the fluid will be changed in the year 2047!  :laugh:
My friendly independent garage did suggest 40K, but even with that, takes us to about the year 2033 at this rate!
I can't believe the same fluid in the gearbox is going to be as effective all these years later, any thoughts at all or should I just go and get it done? 18K is a very low mileage for fluid change I must admit.
Thank you very much.
MK7.5 2020, Isaac Blue, standard spec
Gone but certainly not forgotten Candy White Scirocco 2.0 TSI
Offline Adam T7
Re: DSG Service
« Reply #9 on: 01 July 2026, 21:41 »
To repeat my earlier thread, I do about 4k pa and get my DSG serviced every 3 years.
