Author Topic: Low oil light - what can I put in?  (Read 3150 times)
Offline LSBristol
« on: 07 November 2023, 19:00 »
Got MOT and service tomorrow and oil light (orange) has just come on. Checked and about 2mm below the min on the dipstick. It's a 9 mile drive to the garage in the morning - am I okay to drive? I have a small amount of 20w50 semi synthetic I could chuck in, although I presume this is completely the wrong sort - better than nothing or a no no?
Or do I go and buy a litre of the right stuff for VW to empty out again in the morning?  (anybody know what the spec is?)
2017 mk7.5 non-PP, Indium Grey, manual
1991 T25 Camper
1967 Beetle 1500
Offline LSBristol
Re: Low oil light - what can I put in?
« Reply #1 on: 07 November 2023, 19:42 »
Update - weighed up £10 of oil vs engine damage and decided to go and get some. Found some 504.00 which is one of the "alternative" options in the manual.
1991 T25 Camper
1967 Beetle 1500
Offline Tractor Dave
« Reply #2 on: 07 November 2023, 20:00 »
If it's getting changed when you get to the garage, the 20/50 will do no harm. Warm it up in the house before you add it and just before you leave. It's a little thick for a cold start and as a semi synthetic, won t offer the same protection to your turbo on a high speed run, but will be fine for a short run to the garage.
I always use a cheap semi synthetic oil for first full on a 're built engine. I run it up to temp and drain it after a short run. It acts as a flush.
Offline LSBristol
« Reply #3 on: 07 November 2023, 20:59 »
Thanks that's useful knowledge for the future!
1991 T25 Camper
1967 Beetle 1500
