Author Topic: Heat shield above back cat  (Read 16468 times)
Offline P6GTD
« on: 18 September 2023, 16:33 »
Suddenly today a rattle when I close the boot lid.
Examination reveals the “tin tray” heat shield above the cat has come loose and is sitting on top of the cat box.
Only done 36,000 miles so not pleased.
A known problem?
Any diy cures?
I’m reluctant to go to the dealer and test out my “All In” warranty in case they start to prevaricate.
Offline Adam T7
Re: Heat shield above back cat
« Reply #1 on: 18 September 2023, 17:39 »
On a previous car the heat shield over the Exhaust mid section / Cat started rattling, turned out one of the bracket rivets had corroded through. Quick fix that lasted for about 9 months until I bought a new Heat Shield was a small nut and bolt to hold the shield to the bracket. New Heat shield actually only cost a few quid and was a 10 minute job to replace as access was really easy - not sure on a GTI.
Offline madstaff
« Reply #2 on: 18 September 2023, 18:43 »
It'll be where the steel nut/washer contacts the heat shield and rotted through due to dissimilar metal corrosion.
See it all the time, cut some big washers out of some thin gauge steel sheet for a repair.
Offline ajmoir36
« Reply #3 on: 18 September 2023, 22:20 »
I had to fix my sisters GTI for the same issue. I bought some of these https://www.ebay.co.uk/itm/363729225833 you might be able to buy them from VW cheaper no idea. I pulled the old one off that had rusted and popped it on the stud sticking out of the body and pushed it up using pointy pliers. No more rattle.
This image you can see them near the valance and at the back. I had to do two at the back and managed to do it without jacking it either just!
Diagonally parked in a parallel universe.
On Order: Mk8 R, Pure White, Reversing Camera, Harmon Kardon, Heated seats all round.
Gone: Mk7.5 R, 5dr, DSG, Deep Pearl Black, 18” Cadiz, Nav, Winter Pack, Keyless, Dynaudio and Reversing camera.
Gone: Mk7 R, 5dr, DSG, Limestone Grey, 19" Pretoria's, Nav Pro, DCC, Winter Pack, Keyless, Mobile Prep and Reversing Camera.
Gone: Mk6 GTD, 5dr, Manual, Tornado Red, 18" Vancouvers, RCD510 + Dynaudio, heated seats.
Offline Finglonga
« Reply #4 on: 19 September 2023, 18:23 »
Those clips rust quicker than a Ford Escort Mk3 so rust proof them when putting them on.
Offline SRGTD
« Reply #5 on: 19 September 2023, 19:50 »
Off topic (apologies! :embarrassed:) but on the subject of rusty mk3 Ford Escorts, I bought a mk3 Escort XR3 brand new in 1982. I saw it around 10 years later, long after I’d sold it and it looked remarkably rust free, with no rust in the usual places (e.g. around the wheel arches, along the sills, the bottom of the doors, front wings).
Its generally very good condition and resistance to corrosion was probably down to the copious amount of Waxoyl applied to the underbody and enclosed bodywork sections from new by yours truly, rather than Ford’s 1980’s token gesture towards corrosion protection to keep the tin worm at bay…. :whistle: :grin:
Gone but not forgotten;
2016 Polo GTI; Blue Silk
Offline P6GTD
« Reply #6 on: 01 October 2023, 12:42 »
Back on topic……
I have had various garage opinions, all of whom start with “they all fall down or fall off eventually”.
From there opinions diverge to :
Just ignore it
Take it off, not needed
Get it re-fixed
I suspect my VW “all-in” warranty will exclude the cost of repair/replacement as it will be defined as wear and tear.
Any opinions on any of the above? Must be a common thing surely?
Offline Adam T7
« Reply #7 on: 01 October 2023, 12:49 »
Go for number 3, car manufacturers don’t fit parts if they could avoid and save a few quid.
Offline karlos
« Reply #8 on: 15 October 2024, 23:14 »
Resurrecting this thread to confirm that a loose heat shield isn't covered under the All-In warranty as I found out yesterday. For the pennies it would cost them for the clips and the two minutes it would take to fit them you'd think they'd do it out of courtesy especially as it's a common problem.
Anyway, I've ordered some clips for £3 from ebay.
2017 (67) GTI PP DSG. Tungsten Silver with DCC, Art Velours, Dynaudio, Climate Screen, Tints, Keyless, Rear Camera, Lane Assist, Seville wheels.
Offline SRGTD
« Reply #9 on: 16 October 2024, 09:25 »
No, it’s not covered. The All In warranty essentially covers sudden Electrical and Mechanical failure of covered components and unfortunately an exhaust heat is neither electrical nor mechanical.
Sadly, I think the days of dealers doing little tasks out of courtesy to customers have long since gone; not doing them could ultimately cost the dealership more than the few pennies and the two minutes it would have taken, as some (many?) customers would vote with their feet and take their custom elsewhere.
