Author Topic: Climate screen - do they work?  (Read 6162 times)
Offline willni
Re: Climate screen - do they work?
« Reply #10 on: 01 September 2023, 21:30 »
Yep I've been looking at those especially the blueish tint that looks OE, couple of things.... there still seems to be a lot of questions over legality over the aftermarket tints even though some look the same as factory fit, secondly as I mentioned I need to stick two very sticky permits to my screen and I've no idea if this will work long term on a film applied to the rear of the screen.
Might just resort to a large microfibre cloth draped over the centre console when it gets very hot.
Side note the OEM is a slight red hue on the climate screens.
How often would you apply the KC Top Star to the plastics? Typically with plastic uv protectants they should be applied one a month to once every three months.
Offline Rudedog
« Reply #11 on: 01 September 2023, 22:14 »
Maybe a very quick wipe over with a MF that only has had the Top Star on, thing is it has only affected these certain points... all other areas like the dash down to the screen which gets full-on sun are fine... this is my daily so the wipe down is just to remove dust... the other high use touch point is the passenger door handle + sun visor, the wife always leaves hand-cream marks on it  :sad:
My alternative product would be a very diluted Pol Star but that has no protection.
Offline Jace
« Reply #12 on: 11 September 2023, 12:27 »
Go & speak to a window tinting company, they do clear UV blocking/protective material, its used a lot on shop windows to protect their displays from fading in the sunlight
2018 Golf R 7.5 Estate > Full Revo stg2 set up
