Author Topic: Damp Smell  (Read 8190 times)
Offline greencode
  • Golf R - Pure White
Damp Smell
« on: 17 July 2023, 14:32 »
I have a horrible damp smell from the car interior. I have a feeling it's probably the water that managed to get into the rear footwell due to that annoying speaker seal issue. I have already tried; Removing the mats to rule those out, run a dehumidifier for 48 hours to remove all water in the car but still the smell is there.
Is there anything else I can try/use to eliminate the smell or is likely to have to have gone too far and I need to completely replace the carpet?
Offline uzinusa
Re: Damp Smell
« Reply #1 on: 17 July 2023, 18:06 »
Have you checked underneath the spare wheel for water due to broken drain hose from tailgate handle?
GTI PP 3 door, DSG, Carbon Grey Metalic, DCC, Keyless, Discover Pro
Offline greencode
Re: Damp Smell
« Reply #2 on: 17 July 2023, 18:43 »
Hi. Yeah, I had that issue quite a while back and replaced that drain hose so it’s not that.
Offline Finglonga
Re: Damp Smell
« Reply #3 on: 18 July 2023, 16:27 »
Are you sure it isn't the Air con needing Sanitising as they can stink. A Air Con Bomb would clear it if it is that.
Offline greencode
Re: Damp Smell
« Reply #4 on: 18 July 2023, 16:31 »
I thought that would only smell when I started the AC up? AC is on pretty much all of the time so it could probably do with a freshen up, regardless.
Are those the things you put your AC on full and press the can and leave it to run with the windows/doors closed?
Offline uzinusa
Re: Damp Smell
« Reply #5 on: 19 July 2023, 13:51 »
Isn't there a AC drain hose that runs at the front of the transmission tunnel, accessible under plastic shroud in front of gear stick?  I think this can block (drains under car) and can back up with condensate.
Offline greencode
Re: Damp Smell
« Reply #6 on: 19 July 2023, 14:05 »
Not too sure. I've just bought some Holts Air Car sanitizer so I'll do that later on and see whether that cures the problem. If not, I'll have a look at the drain hose at the weekend.
Offline uzinusa
Offline greencode
Offline GTIreland
Re: Damp Smell
« Reply #9 on: 21 July 2023, 18:50 »
There's also water ingress from the rear wiper seal, boot lid wires, stoplights and boot vents.
2016 Mk7 GTI PP CSG Manual
