Author Topic: noisy ride  (Read 6554 times)
Offline joey
noisy ride
« on: 03 June 2023, 20:36 »
my MK8 life doesn't seem any a better ride than my MK7. and just to prove it, in colder weather, its a rougher and noisier ride, much better in warmer weather. colder weather brings out the parcel shelf rattle, and door seal creaks, and not so smooth over bumps. when its warmer these are quieter.
any of you have similar issues? or is my radio not turned up enough. :grin: :nerd:
Offline SRGTD
Re: noisy ride
« Reply #1 on: 03 June 2023, 21:53 »
Tyres can be a factor in noise levels. What brand and size of tyres do you have on your car? Which model of Golf do you have?
Gone but not forgotten;
2016 Polo GTI; Blue Silk
Offline monkeyhanger
Re: noisy ride
« Reply #2 on: 04 June 2023, 07:59 »
If its Bridgestones, there's your answer - hard in warm weather, like granite discs in colder weather.
Offline Adam T7
Re: noisy ride
« Reply #3 on: 04 June 2023, 09:08 »
I swapped my Bridgestones to Michelin PS5’s - so much quieter.
Offline joey
Re: noisy ride
« Reply #4 on: 04 June 2023, 13:05 »
so i have a 72 plate 148 life model, tyres are the default Nexen, previous MK7 model had Goodyear, which i found were much better and quieter. never had an issue with my MK6 which is still going strong. just seems to be a weaker setup on MK7 and 8's.
Offline SRGTD
Re: noisy ride
« Reply #5 on: 04 June 2023, 13:47 »
Cost cutting over the years might also mean there’s less - and maybe poorer quality - sound deadening material used in the mk8 compared to a comparable mk6 Golf model.
Offline Watts
Re: noisy ride
« Reply #6 on: 05 June 2023, 09:08 »
I put a bit of anti-rattle tape on the stops to quieten down the parcel shelf. Works well for about a year before they need to be replaced. Door seals need lubricating annually with Krytox. You'll be amazed at just how much noise that removes, if you have a sunroof then that needs doing too. I did mine in 2021 and over the last few weeks the creaking and rattles are starting to come back.
Previously:
Offline joey
Re: noisy ride
« Reply #7 on: 06 June 2023, 20:32 »
maybe VW got it wrong, should have thought about 205 60R16 instead of 55R16? as a default tyre.
Offline Kenis
Re: noisy ride
« Reply #8 on: 17 June 2023, 16:54 »
I’ve got a bit of an annoying rattle sometimes within the door or b pillar interior trim. Don’t remember the same in my mk6 on same roads. (My mk8 has DCC and is mostly in comfort)
I do have Bridgestones and truly terrible road surfaces - in France it was fine. My Honda e is worse around the rear view mirror interior trim.
Luckily though no problems with the software not working / bonging. (Lane assist and the odd misreading of speed limits I put in category of how it’s designed to work
Ordered Apr-21 Arrived Mar-23: MK8 GTI Clubsport, Dolphin, Estorils plus other options
