Author Topic: Odd A/C problem  (Read 3268 times)
Offline gadgie
Odd A/C problem
« on: 24 May 2023, 20:33 »
On a long trip recently (200 miles), and on a hot day too,  the air-con in my 2016 mk7 GTI seemed to pack up.
I was getting little or no air from the vents although I could hear the blower running.  I tried the blend-door recalibration but that made no difference.
At the end of the trip I checked the aircon pipes in the engine bay - ice-cold, so perhaps that discounts gas loss. I pulled and replaced the main blower fuse and got cold air again - but the car had been stopped for 30-40 minutes by then.  The cabin air filter looked clean too.
Now, several days later, the a/c seems to be working but I haven't done another long trip yet and the weather hasn't been as hot as on the failure day.
I'll get it checked out at the next service but I wonder if anyone else has had a similar problem? I'm at a loss to explain what the cause of the failure was.
Andy
Offline Carbon VW
Re: Odd A/C problem
« Reply #1 on: 25 May 2023, 23:17 »
Scan the car if possible with VCDS or similar to see if any fault codes are stored in the control modules. That’s a good start
Mk7 CSG GTi 6MF Stage 1, CSS backbox
Offline uzinusa
Re: Odd A/C problem
« Reply #2 on: 20 June 2023, 07:46 »
Worth resetting the flaps in side the car that control the climate? Occasionally mine click by my feet and air flow evidently not as normal. It takes 30 seconds.
https://www.youtube.com/watch?v=VKwx3yvnanM
GTI PP 3 door, DSG, Carbon Grey Metalic, DCC, Keyless, Discover Pro
Offline gadgie
Re: Odd A/C problem
« Reply #3 on: 25 June 2023, 16:11 »
Thanks for the suggestions - I did the reset flaps thing when the a/c first played up and it didn't fix it. I've been away since on a long trip and the a/c tends to last about an hour, maybe 90 minutes before the airflow peters out. Stopping for a quick coffee/pit stop, even only for 15 minutes and on starting again the a/c is back in full flow. For another hour/90 minutes.
I'm wondering now if this is a simple case of low refrigerant. The car is 7 years old...
I'm not superstitious but since the first post on this subject I've had an unrepairable puncture (resulting in 2 new tyres), a faulty schrader valve causing the TPMS to go off on one of the new tyres (puncture scare!) and just the other day I got out of the car leaving the keys inside and it locked itself. It's not supposed to be able to do that!
Andy
Offline Knottlatiger
Re: Odd A/C problem
« Reply #4 on: 01 August 2023, 09:09 »
I've the same issue, did you change the battery recently? Mine is with VW atvthe moment so I'll reply with the issue
Offline gadgie
Re: Odd A/C problem
« Reply #5 on: 01 August 2023, 22:41 »
I didn't change the battery, no. In fact, it hasn't misbehaved recently and the a/c seems to be working correctly.
Hope the dealership can diagnose yours,
Andy
