Author Topic: Discs and pads replacement for 2016 GTI, OEM or other?  (Read 10042 times)
Offline ProtoCulture
Hi all,
Sure the above has been asked before but I'm heading towards needing new discs and pads all round. VW main dealer is obviously asking silly money so I'm surveying the options first.
Are something like, for example, the Brembo discs on Euro Car Parts good? I've read that OEM VW pads are Pagid, but not sure on the discs, Pagid too?
On the wild side are the CS front discs, tempted but they're not cheap, are they even worth considering?
Any options/thoughts most welcome! Thank you.
2016 Tornado Red GTI PP, DSG, Pro Nav, Dynaudio, Park Assist & Camera.
Mods: Revo Stage 1 ECU & TCU remap. Racingline R600 with Inlet pipe, turbo elbow and muffler delete. Clubsport S backbox. Eibach lowering springs. VBT Hooked discs and Racingline RP700 pads, braided lines and RBF660 fluid.
Protrack One wheels (18x8, ET45) 12mm spacer on rear.
Geo by Swift Performance
Offline symonh2000
Re: Discs and pads replacement for 2016 GTI, OEM or other?
« Reply #1 on: 21 March 2023, 08:51 »
I would avoid Brembo brakes supplied by Euro car parts, I have heard many horror stories about them not being as good as you would expect.
I generally buy my brake bits through ebay from sellers such as Partsinmotion, Allcarparts or Mister auto.
The brakes I tend to buy are Textar, TRW, ATE or Mintex. I have always had good results with these brands.
If you usung the car on track it may be worth going for better (Harder) pads but on the road i don't think that they are generally needed, and they usually compromise cold stopping performance.
Golf GTI 7 PP
BMW M140i
Offline willni
« Reply #2 on: 21 March 2023, 11:42 »
I've the same view as SymonH2000, the Brembos are made in China under license and are lower quality than the other brands, but they sell as people think "oh Brembo and they're cheap".
Offline Mott19
« Reply #3 on: 21 March 2023, 14:31 »
I've recently had fitted VBT Discs and Mintex pads on mine. Plenty powerful but not the most budget friendly.
Prior to that I was running OEM discs and Eicher pads. The fade was horrendous and after a short stint of high speed driving you'd almost lose the brake pedal. They're not something to skimp out on!
2016 Golf GTI Performance - Ecotune Stage 2 (352hp/378ftlbs) Ecotune Stage 3 (452hp/464Ft.lbs)
Offline jaceyboy
« Reply #4 on: 21 March 2023, 14:47 »
Father in law used to work in supplying brakes, dont be put off with aftermarket, they used to make discs for all manafacturers incl Brembo, they are all made in the same factory and have to pass strict rules!!
MK7 GTi
Offline joe6
« Reply #5 on: 21 March 2023, 18:36 »
If you want oem then LLparts have good prices on a lot of spares.
« Reply #6 on: 21 March 2023, 20:17 »
Thanks all. I'm actually thinking of sticking with OEM now. Will have to give it some thought.
Would I be bonkers to consider the Clubsport S discs?! They would look fab!  :grin:
Offline Ulysses31
« Reply #7 on: 27 March 2023, 21:07 »
I had my GTI rear discs and pads replaced in September with stock parts. The originals had corroded and scored and the hubs were very rusty. They started going like this very early on from new. The replacements seem to be of a higher quality and have no signs of corrosion in the 7 months over winter that they've been on there so I'd happily recommend sticking with stock parts.
White Golf GTI Mk7.5
« Reply #8 on: 09 April 2023, 20:59 »
By way of an update, I'm looking at the VBT discs and EBC Red stuff pads. Any thoughts or opinions?
Offline silver38
« Reply #9 on: 09 April 2023, 23:15 »
Have you used Brembo pads or discs? Never had a problem. I fitted Pagid brake shoes and cylinders (UK Made?) on a Fabia and the cylinders have started leaking after less than two years, where's the quality there? They are no different to other suppliers probably made for the least cost. Scan the QR code on Brembos and email it to Academy@brembo.it ask where they are manufactured, they'll confirm if genuine or not.
MKVII GTD Manual - Pure White, 5Door, Adaptive chassis control, Advance telephone connection, Climate comfort windscreen, Discover Nav pro, High beam assist, Keyless entry, Sport and Sound pack, Park assist system with steering assist, Rear view camera, Rear side airbags with rear seatbelt warning, Winter pack, 5 Year Warranty
