Author Topic: Removing 7.5 PP rear calipers  (Read 3615 times)
Offline sjw
« on: 08 March 2023, 14:52 »
Went to do my rear pads and discs the other day, and noticed that the calipers didn't match what I'd seen on the videos I'd watched. I'm assuming this is because all the videos were 7s rather than 7.5s, or because I have the PP and the videos didn't.
What I encountered was rather than just a bolt to hold the caliper on, there was a rubber cap to remove. Once done, it seemed like a triple square to get it removed? But the brake line was in the way...
Has anyone done this? I'd appreciate some light shedding on the topic as to how to go about this... thanks!
Offline madstaff
Re: Removing 7.5 PP rear calipers
« Reply #1 on: 08 March 2023, 16:28 »
Should be able to undo the bolts/slider pins with a 7mm hex socket, IIRC, without disturbing the brake line.
Mine looks like this -
Offline ub7rm
« Reply #2 on: 09 March 2023, 09:19 »
Are you talking about splitting the caliper to change the pads or the bolts for the caliper mounting bracket to be able to change the disc?
The caliper mounting frame bolts are indeed triple squares and are pretty tricky to get loose if you're not using a lift - they are tight as buggery and you don't have much space to get at them - low profile M14?? sockets and some extension bars are your friends.
2020 BMW 128ti
2017 Golf GTD Estate
Offline madstaff
« Reply #3 on: 09 March 2023, 10:05 »
To change the pads there is no need to attempt to undo the M14 triple square bolts which hold the pad carrier to the hub, and as ub7rm says they can be a right royal pain to undo.
Just remove the small black caps and undo the sliders with a 7mm hex and you can lift the caliper out the way to change the pads.
I trust youve got something like OBDeleven/VCDS to put the calipers into service position if its got an Electronic Parking Brake??
Offline sjw
« Reply #4 on: 09 March 2023, 13:01 »
Both!
Thanks, I will give that a go. Yes I have OBDEleven :)
Offline madstaff
« Reply #5 on: 09 March 2023, 15:16 »
Be warned those M14 triple squares are normally tight as hell and with restricted access can be a pain to remove.
Tip - get a scriber/pointed pick or something similar to clean out those splines where your socket fits so the socket engages as intended. Ths last thing you want is the socket slipping and damaging the splines. :angry:
Offline MonWoofer
« Reply #6 on: 17 March 2023, 16:22 »
Did mine last week and this same issue. I just moved the brake lines out of the way (albeit tight as hell) to get my wrench in.
Also the 90nm torque requirement for the carrier bolts was really hard to do. I ended up having 3 extension bars and a swivel. I wish i had a lift and not jack stands.
2018 GTI PP 245
Offline willni
« Reply #7 on: 17 March 2023, 17:06 »
That sounds like one way to hit the knuckles  :grin:
Offline sjw
« Reply #8 on: 17 March 2023, 18:08 »
I've got a scar on my knuckles from when I was doing my springs before xmas. Know all about that!
