Golf mk1
Water pump
Topic: Water pump (Read 1392 times)
c3roberts
Just got here
Water pump
20 October 2005, 14:02 »
I need to replace my water pump on my 1989 MK1 cabriolet, but have been told that i will need to remove the timing belt to do so - is this true?
richandhazel
Global Moderator
Forum addict
Re: Water pump
20 October 2005, 14:20 »
No, the water pump runs from the 'v' belt that also drives the alternator. No need to remove timing belt:-
1. Drain the cooling system. See 4.1 Coolant and Cooling System Hoses. Remove the V-belt. See LUBRICATION AND MAINTENANCE.
2. Remove the nut and T-bolt that fastens the camshaft drive belt cover to the coolant pump. Disconnect the remaining hoses from the pump housing.
3. Remove pump and housing assembly. Four bolts hold the coolant assembly to the engine.
4. Disassemble the pump and housing assembly. Remove the pulley(s) from the coolant pump shaft. Remove the seven bolts and washers and separate the pump from the housing.
Assembly is the reverse of disassembly. Use a new gasket between the coolant pump and housing. Tighten the seven bolts evenly until all are torqued to 10 Nm (87 in. lb.). Install the pulley(s). Torque the bolts to 20 Nm (15 ft. lb.).
NOTE-
The power-steering V-belt pulley attached to the coolant pump is marked with the word KLIMA. The mark faces outward (away from the pump) on vehicles with air conditioning, and inward on vehicles without air conditioning.
To install coolant pump: 1. Clean the surface of the engine block where it will be contacted by the pump housing and the O-ring. Install a new O-ring in the recess that surrounds the water outlet.
NOTE-
The O-ring between the coolant pump housing and the engine block does not require sealer.
2. Loosely install the coolant pump on the engine. The two short bolts are used at the top of the pump housing. Torque the four bolts evenly to 20 Nm (15 ft. lb.). Refasten the camshaft drive belt cover to the coolant pump.
3. Install the hoses and refill the cooling system
More info here:-
http://volkswagen.msk.ru/vw_doc/eva2/GE02/ch4.3.html
http://volkswagen.msk.ru/vw_doc/eva2/GE02/ch4.3.1.html
Last Edit: 20 October 2005, 14:25 by richandhazel
Golf mk1
Water pump
