Author Topic: 7.5 GTi DSG holding onto 2nd gear after cold start  (Read 5308 times)
Offline MartC
« on: 11 February 2023, 18:56 »
Guys, wonder if people could offer up their experiences of their DSG cars after a cold start.
Bought the car in summer so first winter with it. It’s a 2019 GTi PP DSG.
Noticed it more recently with the dip in temperature. Start the car from cold, pull off the drive and the car holds onto 2nd gear for a little while with the revs around 2500 rpm. Probably about 20 mph.
When I idle the car for a while, de-icing it, then pull off the drive, it’ll change into 3rd normally. Obviously a bit more temp in the engine, etc. Wondering if it’s normal behaviour, or odd.
Offline mcmaddy
Re: 7.5 GTi DSG holding onto 2nd gear after cold start
« Reply #1 on: 11 February 2023, 19:18 »
My TCR dsg does the same. Probably some sort of gearbox protection.
Offline P6GTD
« Reply #2 on: 11 February 2023, 23:15 »
Normal. The car thinks for itself. Just let it.
Offline Watts
« Reply #3 on: 12 February 2023, 06:03 »
Mine always holds on to second when leaving our local Tesco's car park. Odd but it probably knows what it's doing..
Previously:
Offline MartC
« Reply #4 on: 12 February 2023, 07:47 »
Excellent, thanks for the replies chaps. Much appreciated  :smiley:
One less thing to worry about.
Offline CarbonGTD
« Reply #5 on: 12 February 2023, 21:35 »
Yep, totally normal - mine does exactly the same - otherwise performs faultlessly.
Offline Carbon VW
« Reply #6 on: 13 February 2023, 11:42 »
Just out of interest, what mileage is on the car? As holding onto 2nd once warm is usually fixed by a tramsmission fluid flush/filter change which is due at 40k miles (was on the mk7 anyway)
Mk7 CSG GTi 6MF Stage 1, CSS backbox
Offline MartC
« Reply #7 on: 14 February 2023, 11:23 »
Just out of interest, what mileage is on the car? As holding onto 2nd once warm is usually fixed by a transmission fluid flush/filter change which is due at 40k miles (was on the mk7 anyway)
The issue which thankfully seems to be a non issue was straight after a cold start, more so in this cold weather.
After after around 200 metres, it selects 3rd fine.
Car has only done ~15,000 miles.
Offline Carbon VW
« Reply #8 on: 14 February 2023, 14:06 »
 :cool:
