Author Topic: parking brake binding  (Read 2261 times)
Offline Tornado8
« on: 03 February 2023, 20:05 »
Anyone out there that can help. I had a sachs organic clutch fitted last year. The parking brake started to lock on.
The clutch position sensor was reset and it worked for a while, then went again. In the end I had the sensor
replaced in Oct, this worked until now when the same thing happened. Reset the other day but has not solved the
problem. I can't see it being a clutch problem. Maybe the clutch master or slave cylinder? or needs bleeding? Any
ideas? PS It happens intermittently.
Old, but a serial modder!
