Author Topic: Avon calling!  (Read 243500 times)
Offline SRGTD
Re: Avon calling!
« Reply #380 on: 25 March 2025, 08:34 »
That looks like the exact same issue they have on the ID4.
Closing the door smashes the glass lens on the puddle lights.
Quite a few Cupra owners over on seatcupra.net forum have also had this issue. It’s been suggested on that forum that it might possibly be the heating function of the door mirrors that causes the projected image to become distorted.
Why do VAG feel the need to fit these seemingly fragile image-projector puddle lights? - IMHO a case of form over function. The old style puddle lights with conventional bulbs on the mk6 and mk7 Golfs seemed to work just fine without issue.
If it ain’t broke don’t fix it.
Gone but not forgotten;
2016 Polo GTI; Blue Silk
Offline JoeGTI
Re: Avon calling!
« Reply #381 on: 25 March 2025, 09:07 »
This is a hugely common fault and my understanding has been that it's caused by water ingress, causing the film over the LED bulb to slowly disintegrate. The lenses are not glass (they're plastic) so its not likely to be caused by slamming the doors and neither is the heating element in the mirror likely to be the reason (the bulb is nowhere near close enough to the heating element in the glass).
If warranty isn't an option, they're relatively inexpensive to buy (about £30-£35 per side) and if you're reasonably handy DIY-wise, it's not too difficult a job. Anyone who has swapped their mirror caps themselves for example would have no difficulty doing it.
Offline BillSan
Re: Avon calling!
« Reply #382 on: 25 March 2025, 10:42 »
Funnily enough, I looked at mine this morning on the garage floor and was planning to put pics up later.
Both of mine are much worse than that as the lights are partly now on the car doors and hardly have the 'golf ball' effect at all.  I thought they had moved/become misaligned but it could also be due to broken glass.  (Edit:  Following JoeGTI's post - they must have disintergrated!)
« Last Edit: 25 March 2025, 10:47 by BillSan »
Offline Dav3smith
Re: Avon calling!
« Reply #383 on: 25 March 2025, 10:46 »
Mine were replaced under warranty at the end of Feb. Don't let them fob you off.
GTI Clubsport ED45 DBP, DCC, HK, WP, Pano
Gone Golf R 7.5
Gone GTI 7
Offline Carlosfandango
Re: Avon calling!
« Reply #384 on: 25 March 2025, 15:47 »
The ones on my previous Mk8 were also replaced under warranty, if you’re still within the warranty period they are covered.
Current -
Gone -
2022 Mk8 GTI DSG, Kings Red.
2003 Mk4 R32, Reflex Silver.
1991 AX GT.
1984 Mk1 XR2.
Plus many more.
Offline davo245
Re: Avon calling!
« Reply #385 on: 25 March 2025, 18:23 »
Out of 3 years and into the extended warranty now so will see what they say not holding out much hope but will see how it goes.
Mk6 GTI DSG
MK7.5 GTI performance DSG
Mk8 GTI
Offline BillSan
Re: Avon calling!
« Reply #386 on: 25 March 2025, 21:54 »
Here's mine. This is the passenger side but the driver's side is much the same.  My lease ends in three months so I won't bother with the dealership.  VW, or more likely BCA, can fix it if they want.
Re: Avon calling!
« Reply #387 on: 25 March 2025, 22:06 »
Looks like a bit of modern art BillSan!
Re: Avon calling!
« Reply #388 on: 25 March 2025, 22:42 »
Yes indeed, mine actually didn’t look ‘broken’, just didn’t look like the original pattern, if someone had never seen what they looked like originally, they probably wouldn’t notice an issue tbh.
Current -
Gone -
1991 AX GT.
1984 Mk1 XR2.
Plus many more.
Offline GtIOlly
Re: Avon calling!
« Reply #389 on: 18 February 2026, 17:01 »
The bongs are back (sos, travleasist l, ect) happens just like thay used to , anyone know if a replaced part has individual warranty and if so how long for and failing that how much is this going to cost to assuming ££££, also had the puddle lights fail one replaced a year or 2 ago then the others just gone. 21 reg mk8
Any help is appreciated
