Author Topic: TCR foglight ducts  (Read 5375 times)
Offline JB73
TCR foglight ducts
« on: 25 January 2023, 21:51 »
Hi guys, does anyone know the part numbers for the ducts in the TCR front bumper which are fitted where the fog lights normally are on the regular GTI as I’d like those instead of fog lights
Thanks Jason
Offline mcmaddy
Re: TCR foglight ducts
« Reply #1 on: 26 January 2023, 09:38 »
Will it still pass an MOT? I thought if it came from factory with fogs it still needed them to pass an MOT. Assuming you are in the UK.
Offline madstaff
« Reply #2 on: 26 January 2023, 10:10 »
You only need to inspect front fog lamps fitted to vehicles first used on or after 1 March 2018.
Offline mcmaddy
« Reply #3 on: 26 January 2023, 19:51 »
Offline JB73
« Reply #4 on: 27 January 2023, 12:23 »
Oh yes, I forgot about the MOT side of it. I might think of trading my existing car in for a TCR then
Cheers Jason
Offline fredgroves
« Reply #5 on: 27 January 2023, 13:40 »
I'm not entirely convinced thats correct about the fogs...
The MOT requirement is to test them IF they are fitted and IF the vehicle was first registered after 1st March 2018.
There is nothing that says either its a legal requirement to have them on a new vehicle OR that if you removed them it would fail an MOT.
Basically, if they are fitted they have to work. Not fitted or uninstalled, can't be tested.
One rear foglight is the only UK legal requirement.
Offline jv
  • Administrator
« Reply #6 on: 27 January 2023, 14:16 »
Suppose it depends how far you take 'fitted', when the ultra vigilant tester turns the switch to turn them on.
Justifying trading to a TCR based on having ducts instead of fogs is straight out fabulous though and should be encouraged.
Buy site stuff!
GolfGTI.co.uk - merchandise
Support the forum charity!
Online Watts
« Reply #7 on: 27 January 2023, 16:47 »
Exactly, I love that! :laugh:
Previously:
Offline mcmaddy
« Reply #8 on: 27 January 2023, 18:52 »
Cheers Jason
Offline fredgroves
« Reply #9 on: 28 January 2023, 18:32 »
Just another factory option that wasn't fitted... I mean its obvious there aren't any on the front...
