Author Topic: anyone with etka help if you can :d  (Read 1095 times)
Offline Rain
  • forum irregular
« on: 20 October 2005, 13:32 »
i need to replace the metal coolant pipe on an 8v pb(digifant) if anyone knows if vw still do it or anywhere that does can you let me know as mine has rotted in the middle and sprung a leak, at the moment it only leaks when under pressure but its not goner last much longer :S
(btw its the metal pipe that goes from right side of engine round and under the oil cooler/filter housing)
Offline richandhazel
Re: anyone with etka help if you can :d
« Reply #1 on: 20 October 2005, 14:42 »
GSF do it:-
17875 WATER PIPE-METAL  G2 1.8 8v F.Inj 8/83 >10/91  £16.60
and Stuart should be able to get you one from Eurocarparts:-
Pt No: 211440860, £17.84
Offline Rain
  • forum irregular
« Reply #2 on: 20 October 2005, 14:45 »
cheers rich  :wink:
got a fair bit of work for myself lol need to do the thermostat the rocker cover gasket and sort the side light wiring out :S
« Reply #3 on: 20 October 2005, 15:44 »
Ah that shouldn't take you too long. That pipe can be a bit of a swine but not too bad. Don't forget some anti-freeze too :wink:
« Reply #4 on: 20 October 2005, 17:25 »
Buy both of the plastic flanges that attach to the front & side of the block while you're going to be draining out all your coolant, might be a good time to give it all a good flush through with a hosepipe too :)
Offline Rain
  • forum irregular
« Reply #5 on: 20 October 2005, 20:25 »
it had a good flush the matrix went lol and i couldnt get it to heat up when i replaced it must have drained it about 6 times :S dam valve was backwards lmao but im not too sure what your talking about with the plastic flanges but the hosepipe flush sounds messy :P
yer rich i ordered a 5 litre thingy of anti freeze :D
« Reply #6 on: 21 October 2005, 08:43 »
I'm talkin about the one at the front of the block with the temp senders in, it joins to the top radiator hose, and the one on the right side which connects to the heater matrix feed hose.  These are prone to leaking and are dirt cheap to buy so defo worth replacing while you're draining the coolant.
Offline Rain
  • forum irregular
« Reply #7 on: 21 October 2005, 17:09 »
ah ok i got ya if anyone knows the the gsf item code would be helpful or the vw part number :D
