Author Topic: DSG paddle extensions from the MK7, do they fit?  (Read 4146 times)
Offline The_Doc
« on: 24 December 2022, 16:55 »
Anyone know if the paddles are the same between the generations? I have some leyo extenders from my old 7.5 and wonder if it’s worth keeping them for my 8.
Current - MK8 CS - Dolphin Grey, DCC, Black Estoril, Rear Camera, Sunroof, Winter Pack, Harmon Kardon
Previous and sorely missed - MK7.5 GTI Perf, Indium Grey, Brescias, Art Velours, Rear Camera
Offline Carlosfandango
Re: DSG paddle extensions from the MK7, do they fit?
« Reply #1 on: 24 December 2022, 17:20 »
The GTI paddles on the 7/7.5 and 8 are different, but there is a different wheel on some other models (life etc) that has different paddles I believe, so it depends on which car you have.
« Last Edit: 01 January 2023, 08:17 by Carlosfandango »
Current -
Gone -
2022 Mk8 GTI DSG, Kings Red.
2003 Mk4 R32, Reflex Silver.
1991 AX GT.
1984 Mk1 XR2.
Plus many more.
Offline The_Doc
« Reply #2 on: 24 December 2022, 17:39 »
Im awaiting a Clubsport, paddles were from an old GTI. I figured it had different paddles since leyo sell them as separate items, but wanted to check. I’m definitely picking up a set, they were cracking!
Offline fredgroves
« Reply #3 on: 24 December 2022, 22:54 »
From what I've read the only way of changing them on the mk8 is to swap them for the mk8 R ones as the paddles themselves are not removable, you have to swap the entire unit.
Videos out there to show you how, not too tricky it seems...
Offline The_Doc
« Reply #4 on: 29 December 2022, 21:45 »
For anyone coming here for an answer in the future, I wook my old extenders from the mk7 down to the dealer and offered them up to the paddles on a mk8, its a definite no.
Offline Carl_45
« Reply #5 on: 31 December 2022, 18:05 »
From what I remember when I changed my CS paddles to the R ones, there is a pin like the mk7/7.5, however, it’s further inboard under the airbag.
I looked into this a bit myself before going for the R paddles as a work mate has the Racing Line paddles on his Polo GTI, they’re nice.
For what it’s worth, the R paddles are worth the upgrade! If you find my and others guidance on here it’s straight forward to do. If I recall, the most import step is DO NOT turn on the ignition with the airbag electronics disconnected, you will get an error that requires OBD to reset.
I didn’t get an error, some did, I think we worked out it was the turning on the ignition with the airbag on the passenger seat that was the difference :rolleyes:
Past: Clubsport 45, kings red…. Gone too soon!
Offline The_Doc
« Reply #6 on: 06 January 2023, 20:37 »
The Leyo extenders fasten over the existing paddles, and clamp to them with a grub screw on the bottom, rather than replacing the paddles.
Thanks for the advice on the paddle change though, I’ll make sure to keep that in mind if I do go that route.
