Author Topic: Washer fluid cap  (Read 8632 times)
Offline sjw
Washer fluid cap
« on: 14 November 2022, 11:54 »
Is it normal for these to just not fit at all? Every time I go to fill my washer fluid up I struggle with, and then give up on, getting the damn thing to clip on properly. The whole thing comes off, which can't be right. I know some people put a Skoda/Audi one in
Offline LSBristol
Re: Washer fluid cap
« Reply #1 on: 14 November 2022, 14:22 »
Mine clips in fine without any real effort. It definitely shouldn't all come off.
2017 mk7.5 non-PP, Indium Grey, manual
1991 T25 Camper
1967 Beetle 1500
Offline sjw
« Reply #2 on: 14 November 2022, 14:39 »
Maybe it came off once and I've put it back in the wrong order. I struggled with it for 5 or 10 minutes the other day before I just shoved it on as best as I could in a huff
Offline Ceefeesh
« Reply #3 on: 14 November 2022, 17:17 »
The originals do come off and will go back on. One of these will fit but if you’re minded you might find it cheaper elsewhere!
https://www.theskodashop.co.uk/products/lid-funnel-for-windscreen-washer-tank
Offline sjw
« Reply #4 on: 14 November 2022, 17:28 »
Maybe someone can explain to me how it's supposed to fit, because I can't figure it out!
Two pieces come off: the filter, and the blue ring. Which is supposed to go on first?
The blue ring/cap part has little tabs that look as if they are supposed to fit under another part. Which part does it clip on to?
I showed my brother and my dad, and they couldn't figure it out either. It honestly feels like at some point they've been replaced with parts for a car that has a pipe diameter of like 2mm less!
Offline Ceefeesh
« Reply #5 on: 14 November 2022, 18:00 »
From memory the blue ring goes on first and the filter slides into it.
Offline Jace
« Reply #6 on: 02 December 2022, 10:05 »
I've got one of these rubber caps & I think I paid about £10 for it.
It does finish it off better than that cheap OEM thing they use.
2018 Golf R 7.5 Estate > Full Revo stg2 set up
Offline Jace
« Reply #7 on: 02 December 2022, 10:06 »
The one Lamborghini use is slightly smaller in diameter than the VW version, I know this as they do theirs in Black & I bought one only to find out it doesn't fit 🤦‍♂️
Offline AGB
« Reply #8 on: 03 December 2022, 11:02 »
Don't think it matters - the OEM part is really poor quality. VW will probably try and tell you it's for performance being lightweight.  :whistle:
Take a look at this YouTube link, it shows the removal of the OEM.
From memory, I think you remove the cap assembly and then the filter as the filter has a lip which seats it on the aperture of the pipe. It then acts as a retainer for the lid assembly to stop it coming off as easily. If you yank it hard enough, the lower part of the assembly will catch the filter and pull it out at the same time.
MK7 Clubsport S, 981 Cayman GT4, MK7.5 GTI TCR
Offline symonh2000
« Reply #9 on: 03 December 2022, 17:07 »
I saw somewhere about the cap being swappable for a Skoda Octavia item. It has an inbuilt funnel to help with refilling.
Golf GTI 7 PP
BMW M140i
