Author Topic: Clutch pedal sticking on the way up  (Read 14403 times)
Offline jaceyboy
Re: Clutch pedal sticking on the way up
« Reply #10 on: 07 November 2022, 13:15 »
Any fluid leaking under the engine tray? mine was slowly coming out and unfortunately it was, seems to be  a common fault as made of plastic
MK7 GTi
Offline symonh2000
« Reply #11 on: 07 November 2022, 15:01 »
I haven't really looked since last night. I will check later, I did make a mental note of where the fluid level was sitting.
If I do decide to get the spanners out is this kit any good?
https://www.awesomegti.com/shop-by-brand/sachs-performance/sachs-performance-clutch-kit-for-volkswagen-golf-mk7-gti/
« Last Edit: 07 November 2022, 15:05 by symonh2000 »
Golf GTI 7 PP
BMW M140i
Offline jaceyboy
« Reply #12 on: 07 November 2022, 19:37 »
I never noticed a fluid drop in the top up, but it was dripping out of the gearbox and then onto the garage floor, some explode, some don't like mine and I was able to top it up and get it to a garage
MK7 GTi
Offline symonh2000
« Reply #13 on: 07 November 2022, 20:31 »
I did check again, I couldn't see evidence of a fluid drop or any leaks.
The pedal feels fine 99% of the time except for the random occasion that the pedal doesn't return fully. When I have had slaves go on other cars I have had problems with the clutch not disengaging, not so much a pedal not returning.
It is just a shame that the weather is so crap as it doesn't do my enthusiasm for fixing it much good.
But if I do the job I will be fitting uprated parts, so that the car is more remap friendly in the future. I have held off any modifications so far due to the clutches being a bit weak.
« Last Edit: 07 November 2022, 20:33 by symonh2000 »
Golf GTI 7 PP
BMW M140i
Offline madstaff
« Reply #14 on: 07 November 2022, 20:57 »
I would be replacing the master cylinder at the clutch pedal first as its the easiest and cheapest option.
https://youtu.be/Gc-Hjx1Bsh0
Offline symonh2000
« Reply #15 on: 07 November 2022, 21:50 »
I think I will do that Madstaff. I will order one tomorrow.
Shall I go genuine for about £150 or get a Sachs, LUK, or Febi one for about £85?
I am guessing that Sachs or LUK would be the OEM
« Last Edit: 07 November 2022, 21:56 by symonh2000 »
Golf GTI 7 PP
BMW M140i
Offline madstaff
« Reply #16 on: 07 November 2022, 22:13 »
I'm sure the master cylinder is nowhere near £150.
I seem to remember the genuine one I got from TPS was cheaper than that.
Offline symonh2000
« Reply #17 on: 07 November 2022, 22:21 »
I haven't checked with TPS yet as they are closed, that was the cheapest genuine one I found online.
I will give them a shout tomorrow as they are only down the road from my work.
Thank you for the help. :)
Golf GTI 7 PP
BMW M140i
Offline madstaff
« Reply #18 on: 07 November 2022, 22:32 »
I seem to recall it was around £85..........
Offline symonh2000
« Reply #19 on: 08 November 2022, 18:41 »
Master cylinder will be in on Friday.
The car has behaved pefectly today...
Golf GTI 7 PP
BMW M140i
