Author Topic: wiper auto  (Read 4580 times)
Offline mossy69
  • 2014 Gtd carbon grey pro nav dyn audio keyless wp
wiper auto
« on: 27 August 2022, 17:41 »
cannot seem to get my auto wipers working do you have to have the stalk up to intermitted or the first wiper setting ,,,mines a golf Gtd 2014 don't know if I have it on mine cheers
2021 Gti moonstone grey 19 Adelaide HUD winter pack
2014 GTD carbon grey pro nav dyn audio keyless
Offline clubsport
Re: wiper auto
« Reply #1 on: 27 August 2022, 18:14 »
Effectively intermittent, put the lever in the first up position from "off" & the wipers should wipe once, and not continue to wipe, if it is dry day.
To test, with lever in this position pour some water on the (outside of) windscreen on the round sensor you can see on the inside of the windscreen in front of the rear view mirror.
If the wipers don't come on, it may be a problem with the sensor? Obviously not an exact diagnosis over the internet.
Offline mossy69
Re: wiper auto
« Reply #2 on: 29 August 2022, 15:40 »
Thanks for getting back mine must be knackered the intermittent wipe stays on all the time , I’ve set in the infotainment screen too
Offline ajmoir36
Re: wiper auto
« Reply #3 on: 01 September 2022, 19:12 »
The switch on the top sets the sensitivity too, far left not very sensitive, far right very sensitive, very little rain will cause it to white more often. So to really test throw it all the way to the left and it should white more intermittently, with longer delays between it.
Diagonally parked in a parallel universe.
On Order: Mk8 R, Pure White, Reversing Camera, Harmon Kardon, Heated seats all round.
Gone: Mk7.5 R, 5dr, DSG, Deep Pearl Black, 18” Cadiz, Nav, Winter Pack, Keyless, Dynaudio and Reversing camera.
Gone: Mk7 R, 5dr, DSG, Limestone Grey, 19" Pretoria's, Nav Pro, DCC, Winter Pack, Keyless, Mobile Prep and Reversing Camera.
Gone: Mk6 GTD, 5dr, Manual, Tornado Red, 18" Vancouvers, RCD510 + Dynaudio, heated seats.
Offline Ej1749
  • Hey all! I may need some help.
Re: wiper auto
« Reply #4 on: 02 September 2022, 11:00 »
I have a 65 plate GTD and mine have never worked as far as I'm aware. All I seem to be able to do is change the speed of the intermittent wipe thingy. VW have assured me I have auto wipers. The closest thing to auto wiping are the wipers slowing down when at a stop at traffic lights... like most cars
GOLF GTD 65 MK7 STAGE 1
Offline Lordie
Re: wiper auto
« Reply #5 on: 06 September 2022, 20:56 »
The auto headlights are great, but I really can't stand automatic wipers  :huh:  They have a mind of their own and rarely work as they should. I have mine set to the highest sensitivity and even then it's hit/miss, and when it does rain I'm forever changing the sensitivity switch on the top as I'm driving but it's a losing battle. I miss having manually controlled wipers  :grin:
Offline SRGTD
Re: wiper auto
« Reply #6 on: 06 September 2022, 21:25 »
Agree. I hardly ever use auto wipers for the same reason. I use the single flick wipe function instead - a quick push down on the wiper stalk to give a single wipe when it’s needed is much more effective IMHO.
Not auto wipers, but the cars with the best intermittent wipers that I’ve owned were a 1982 mk3 Ford Escort XR3 and 1984 mk3 XR3i. Those cars had a rotary control which gave an infinitely variable time delay adjustment between each sweep of the wipers when using them in intermittent mode.
Gone but not forgotten;
2016 Polo GTI; Blue Silk
Offline Lordie
Re: wiper auto
« Reply #7 on: 09 September 2022, 16:54 »
Auto wipers are definitely a step backwards from manual ones :rolleyes:. Was never something I needed or wanted on a car
Offline Finglonga
Re: wiper auto
« Reply #8 on: 10 September 2022, 16:30 »
Found them to work faultlessly on my MK7, just turn them on and forget about them. Was worried every time I had a screen replaced they would stop working as well but so far it has made no difference.
