Author Topic: Smoke… HELP!  (Read 3498 times)
Offline zainahmed48
Smoke… HELP!
« on: 28 July 2022, 14:52 »
Hi all,
I’ve seeing this bluish smoke on startup occasionally.
Only occurs after it’s been sat for a while - doesn’t happen when idling or driving.
Mods as follows:
Stage 1 mapped
Pikey R600 mod
forge turbo blanket
Centre res delete
Clubsport Backbox
I’m still on the original IS20 and stock downpipe. On 33000 miles
https://streamable.com/f8jy1g
Any ideas of causes/fix/cost? Help appreciated
« Last Edit: 28 July 2022, 15:20 by zainahmed48 »
2018 Indium Grey MK7.5 GTi (Manual), 19" Brescia
Offline Watts
Re: Smoke… HELP!
« Reply #1 on: 28 July 2022, 15:14 »
Valve stem oil seals seems most likely. They should be able to be changed without removing the head.
Previously:
Offline zainahmed48
Re: Smoke… HELP!
« Reply #2 on: 28 July 2022, 15:16 »
Reckon it is something I can do at home? I’m quite handy and have plenty of garage space if I move things around.
Offline Watts
Re: Smoke… HELP!
« Reply #3 on: 28 July 2022, 17:54 »
Quite possibly but first of all you need to be sure it is the issue. Well worth getting a decent indie to diagnose first?
Previously:
Offline zainahmed48
Re: Smoke… HELP!
« Reply #4 on: 29 July 2022, 00:02 »
yes going to try and get it booked asap, feeling quite paranoid lol
would you say it is okay to drive or should I avoid if possible? my GTI is my daily
Offline karlos
Re: Smoke… HELP!
« Reply #5 on: 29 July 2022, 00:52 »
I wouldn't be too worried about a puff of smoke on startup. If it smokes under acceleration once warmed up then I'd be a bit more concerned. In the meantime keep an eye on the oil level.
2017 (67) GTI PP DSG. Tungsten Silver with DCC, Art Velours, Dynaudio, Climate Screen, Tints, Keyless, Rear Camera, Lane Assist, Seville wheels.
Offline madstaff
Re: Smoke… HELP!
« Reply #6 on: 29 July 2022, 08:45 »
Im pretty sure to replace the valve stem seals is a camshaft out job on these engines, so unless your really handy its not something id advise attempting on your drive.
Offline Finglonga
Re: Smoke… HELP!
« Reply #7 on: 02 August 2022, 10:15 »
Have you checked the EGR Valve?
