Author Topic: Oil temperature?  (Read 4627 times)
Offline joe6
Oil temperature?
« on: 12 July 2022, 15:46 »
My oil temperature briefly hit 180c in my 7.5 pp having followed a hgv for a while and then overtaking in third before dropping back to 150/160. Never had this temp in any other car. Is this normal? Is the hot ambient temp to blame?
Offline madstaff
Re: Oil temperature?
« Reply #1 on: 12 July 2022, 15:54 »
Are you sure 180 degrees centigrade??
I dont think ive ever seen mine above about 110 degrees c.
Offline clubsport
« Reply #2 on: 12 July 2022, 17:01 »
As Madstaff says, 110 c is about as high as many of us have ever seen on these engines....
I would have thought the engine management system would have lit the dash up with lights and put the car into limp mode. tp prevent any damage to the engine?.... Run a few OBD tests to see what codes you find, there may be an issue with cooling fans not working?
Offline Adam T7
« Reply #3 on: 12 July 2022, 17:03 »
That’s hot, very hot. 180 Fahrenheit is about 80 Centigrade?
Offline DCmk3
« Reply #4 on: 12 July 2022, 17:09 »
Are you sure it was 180c? What was your coolant temperature at?
Operating temperature for the oil on the factory tune should see 100-110c and going up to at most 120c+- under high load.
2014 Mk7 GTI - Littco L500
Offline joe6
« Reply #5 on: 12 July 2022, 18:22 »
Water temp was steady at 90. Will run a scan tonight to see what that shows. No emls showing. I regularly see 140 for the oil.
Offline clubsport
« Reply #6 on: 12 July 2022, 19:48 »
Either the guage is faulty or you are running sunflower or cooking oil? An oil temp of 90, suggests an efefctive cooling system, or again faulty guage (unlikely).
A quick google suggests high performance car oils start to break down at around 125 degress C and are almost ineffective above 135 degreeS C ?
Even allowing for a margin of error, I can't see the car making progress with an oil temperature of 180 degree C.
Offline joe6
« Reply #7 on: 12 July 2022, 19:59 »
Only one fault code for second fob low battery. I think it must be a faulty sensor although I would have thought that would show as a fault? Dealer filled with 0w20 at the last service 6 weeks ago.
Offline madstaff
« Reply #8 on: 12 July 2022, 20:01 »
Faulty temp sensor or a problem with the oil heat exchanger perhaps??
Offline Finglonga
« Reply #9 on: 12 July 2022, 23:46 »
That is the wrong oil, 5w30 or 0w30 but not 0w20.
