Author Topic: Tyre pressure sensors issue  (Read 10075 times)
Offline Mileymk6
« on: 12 July 2022, 11:20 »
Hi
My mk6 has a tyre pressure sensor warning light on the dash, tried to reset via button in glovebox but to no avail, it’s a 2010 with factory 18” monzas.
Any suggestions?
2010 Mk6 3Dr, Blue graphite, 18” Monzas, rns310 Dab with Dynaudio, standard apart from Stainless exhaust. Called Miley cos it’s done a lot of miles!!
Offline ARH17
Re: Tyre pressure sensors issue
« Reply #1 on: 12 July 2022, 12:38 »
Hi
Any suggestions?
Not really helpful but I seem to have the opposite problem. The tyre pressure warning light doesn't come on at all for me. I had tyres below 16 psi and the computer didn't pick it up 😵‍💫
Offline jv
  • Administrator
« Reply #2 on: 12 July 2022, 12:59 »
Hi
Any suggestions?
Held the button down until it beeps then gone for a drive?
Buy site stuff!
GolfGTI.co.uk - merchandise
Support the forum charity!
Offline Mileymk6
« Reply #3 on: 12 July 2022, 13:31 »
Hi
Any suggestions?
The problem is it doesn’t beep no matter what you do
Offline jv
  • Administrator
« Reply #4 on: 12 July 2022, 13:47 »
So with ignition on, not driving, holding down the button for a few seconds doesn't cause a reset beep?
Buy site stuff!
Offline Mileymk6
« Reply #5 on: 12 July 2022, 15:15 »
Nothing, no beep, light stays on engine running or not.
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #6 on: 12 July 2022, 17:28 »
If its not resetting by holding down for ages then there maybe a fault. It can also be reset using VCDS if you can find someone local with a cable.
Current Garage:
35+ years of GTI ownership.
Offline Mileymk6
« Reply #7 on: 12 July 2022, 17:44 »
How would I get a diagnosis?
Could it be a sensor in one of the wheels or do they not work like that?
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #8 on: 12 July 2022, 17:47 »
No sensors in the wheels. It works by rolling diameter by looking at the signals from the ABS sensors and seeing what difference there is.
Current Garage:
Offline Mileymk6
« Reply #9 on: 12 July 2022, 19:37 »
Right, no abs lights on though.
