Author Topic: Questions/Queries  (Read 4064 times)
Offline Vwjap
Re: Questions/Queries
« Reply #10 on: 23 May 2022, 18:00 »
Yeah can belt doesn’t go round the alternator 😉
Offline jonesltd
  • MK7 R
« Reply #11 on: 23 May 2022, 18:30 »
Just saw a belt and assumed cam belt 😂
If you cant find it......Grind it
Offline Watts
« Reply #12 on: 23 May 2022, 21:23 »
Keep some cash handy for the waterpump/thermostat housing which leak, unless there is history of it having been replaced recently.
Previously:
Offline jonesltd
  • MK7 R
« Reply #13 on: 24 May 2022, 09:39 »
full service history from dealership but doesn't mention about pumps
Offline Finglonga
« Reply #14 on: 24 May 2022, 11:57 »
Very common problem, I have just had my third one as it was leaking yet again. Luckily it is the only known major issue with the 7 and 7.5. Don't use a dealer unless it is warranty when yours needs doing as they are next to useless and expensive. Find a good independent garage, luckily the local one to me knows his stuff.
Offline martin998877
« Reply #15 on: 02 June 2022, 20:43 »
I think the chain does have to be replaced though - at 60k miles or 5 years rings a bell?
Golf GTi Mark 7 owner
Offline Carbon VW
« Reply #16 on: 04 June 2022, 00:25 »
Well it shouldn’t ring a bell as there is no set interval for chain replacement. Regular oil changes will keep your chain going well with no issue to double that mileage. There is an inspection chamber down low on the chain cover where you can check the tensioner.
« Last Edit: 04 June 2022, 00:30 by Carbon VW »
Mk7 CSG GTi 6MF Stage 1, CSS backbox
