Author Topic: Haldex oil change  (Read 4124 times)
Offline bsides
Haldex oil change
« on: 20 May 2022, 14:43 »
Hi guys, I’ve a gti mk 7 and VW are advising the above oil change. However when I quizzed them on when it should be done they couldn’t answer - just wondering when it should be don? Mines a mk7 gti 6 years old with 44k on the clock ? Cheers
Offline clubsport
Re: Haldex oil change
« Reply #1 on: 20 May 2022, 14:54 »
There is quite an extensive thread covering servicing of the diff.
https://www.golfgtiforum.co.uk/index.php?topic=278784.0
I recall the schedule being 3 years, or 10k miles.
I assume your car is a Perfomance pack, as the regular mk7 GTi did not have the upgraded diff, hence no haldex fluid change required.
Offline bsides
« Reply #2 on: 20 May 2022, 15:07 »
Yes it is and thanks for the thread. Looks like it’s long over due
Offline madstaff
« Reply #3 on: 20 May 2022, 16:41 »
Make sure whoever does it removes the pump and cleans the screen filter (white piece in the pic)
When I did mine, which was long overdue, the filter was clean, but it's worth doing anyway for peace of mind.
Bit of a thread here too, https://www.golfgtiforum.co.uk/index.php?topic=288457.0
« Last Edit: 20 May 2022, 16:51 by madstaff »
Offline symonh2000
« Reply #4 on: 23 May 2022, 12:29 »
Mine needs changing too, where is the best place to buy the fluid/service kit?
I have seen the kit at awesome GTI but it is very expensive, the fluid is £24 on ebay but the kit is £88 at Awesome, and only comes with two O rings and two bolts extra...
« Last Edit: 23 May 2022, 12:41 by symonh2000 »
Golf GTI 7 PP
BMW M140i
Offline madstaff
« Reply #5 on: 23 May 2022, 14:22 »
Ive serviced my own Clubsport VAQ diff and a friends Golf R Haldex and didnt replace the "O" rings on the pumps on either, and neither have leaked from the pumps.
I think the "O" rings for the pump are £20 odd from TPS.
Got the fluid from here - https://www.ebay.co.uk/itm/255527403203?hash=item3b7e9ebec3:g:JgoAAOSwHmJfAYnw
A pump relearn is not strictly required but recommended if you clean the filter.
Offline symonh2000
« Reply #6 on: 23 May 2022, 14:31 »
Thanks for that, I watched a video on youtube and it said that the filler and drain plugs are single use, but considering that they are metal and have an o ring I would have thought that just new O rings would be fine there as well?
I have a kit at home with a selection of metric sizes so I am sure to have a couple the correct size, but we use reuse O rings all the time at work and providing there is no visible damage they are always ok when reused even under high vacuum or positive pressure.
Golf GTI 7 PP
BMW M140i
Offline madstaff
« Reply #7 on: 23 May 2022, 14:35 »
I reused the original fill and drain plugs and "O" rings too, there shouldn't be any reason not to reuse the "O" rings unless, like you say, you can see signs of damage.
Get yourself a good syringe for pumping the fluid back in too.
Offline symonh2000
« Reply #8 on: 23 May 2022, 16:26 »
That is excellent info, thank you for the help. :)
Golf GTI 7 PP
BMW M140i
Offline clubsport
« Reply #9 on: 23 May 2022, 19:01 »
When I replaced my fluid, I followed instructions and ran around to buy the correct fluid and drain / refill plugs from TPS (around £16). Although I used the new ones there was nothing wrong with the old drain / refill plugs, looking at the size of them and low torque there was no chance of any stretch.
