Author Topic: GTD on 19' Adelaides - Very firm ride.  (Read 9213 times)
Offline Alienatrix
« on: 17 May 2022, 10:41 »
Picked up the car last week with 5 miles on the dash.
Great car overall, fantastic to drive. It was deffos worth the 12 month wait to get it.
But, my god I wish I the demo car I test drove last year when ordering had the 19's on. The demo had the standard 18's.
The ride on 19's is firm. Previous car was an A220d (W177) so not exactly the softest suspension either.
Probably doesn't help that the 19's on the GTD also have the GTI front shockers.
Offline fredgroves
Re: GTD on 19' Adelaides - Very firm ride.
« Reply #1 on: 17 May 2022, 12:24 »
Its "firm".... low speed is definitely a bit lumpy, not bad once you get a bit of a move on though.
Do you have DCC?
Offline Alienatrix
« Reply #2 on: 17 May 2022, 12:40 »
I don't unfortunately.
Have heard that it makes a big difference having DCC.
Budget didn't allow me to stretch to that much.
You're right that, once you go over a certain speed it becomes less noticable, until you hit a pothole :grin:
Offline BillSan
« Reply #3 on: 17 May 2022, 13:04 »
I went with 18's when I replaced my standard Belvederes purely on the basis of views from other owners here.  I've never been in a car with 19's so I don't know if it would be a problem for me. My car doesn't have DCC and I'm happy with what I've got.  :smiley:
Offline fredgroves
« Reply #4 on: 17 May 2022, 13:50 »
I drive around most of the time in "moon buggy mode" (comfort+) because of the bloody dreadful roads. Unless I'm having a blat and the roads are smooth.
I test drove a Mk8 GTI on 18's without DCC and that was no problem at all - its definitely the large, super heavy aussies that's doing it. If I could be arsed, I'd look for some lighter 19's or even 18's (although that gets expensive when you factor in new rubber all round). Lighter would improve it no end.
« Reply #5 on: 17 May 2022, 14:07 »
What tyres are you running Alienatrix?
19’s + Bridgestones + 40 plus psi would be uncomfortable for sure.
First step is to drop the tyre pressures to around 38psi, that takes the edge off.
I run a Clubsport with crud iron heavy 19’s and Michelin tyres so in effect have slightly stiffer suspension than you again, but it’s fine for road use even ferrying almost octogenarians on odd occasions.
Yes, really bad roads will jar a bit but I’ve recently done some bad roads in a small SUV with balloon tyres which was actually hardly any better for ride comfort and noise transmitted into the cabin.
I do drive around potholes as much as humanly possible but some bits of badly worn tarmac are unavoidable and I find the ride quite acceptable with no DCC and 19’s.
Offline Alienatrix
« Reply #6 on: 17 May 2022, 14:24 »
Factory Hankooks (Ventus S1 Evo 3).. not checked pressures to be fair.
That will probably be my next move.
I just didn't think the 19's would make it that bloody firm  :grin:
« Reply #7 on: 17 May 2022, 15:43 »
Tyre pressures do make quite a difference.
I had a BMW M135iX for a short while and reducing the tyre pressures made the car less fidgety and more comfortable.
Offline Alienatrix
« Reply #8 on: 17 May 2022, 22:02 »
Not wanting to change the subject too much here, but...What tyre would you guys choose for outright sport performance.
A summer tyre would be fine, car won't be used during winter as I work away from home.
I've been reading through Tyre Reviews website and at the moment the top 3 seem to be:
Pilot Sport 4s
Sport Contact 7
F1 SuperSport
Or, would you wait for the Pilot Sport 5s when it's released some time next year hopefully?
Offline fredgroves
« Reply #9 on: 17 May 2022, 22:05 »
Only a Ps5 at the moment, not the S version. Not very highly rated, not a ultra performance tyre.
I've got ps4s's now.
Toss up between that and the new Eagle f1's. The eagles were more expensive and not available for a week and I had a puncture. Think the tyre test guy says the eagles have better feeling but can't knock the ps's, really super grippy.
