Author Topic: oil pressure do not exceed 4000 rpm message and epc light  (Read 4849 times)
Offline steve hunt
got this fault poping up regularly when pushing the engine ,have changed both oil pressure switches to no avail
also won't show oil temp on dashboard display changed sensor assembly in sump -no different
has any one else experienced these problems
Offline bgbazz
  • If it aint broke...I can fix it!
I can't help with the oil temp issue, but have you considered the possibility that the oil pressure sensors are just doing their job and the pressure IS outside the normal parameters?
Just wondering.
« Last Edit: 09 May 2022, 05:42 by bgbazz »
Mk4 Golf TDI Estate 4Motion, remapped 1.9. Sweet runner = keeper. She is the 66th vehicle I've owned and hopefully, the last.
