Author Topic: Tracker  (Read 4707 times)
Offline Fisher2022
Tracker
« on: 08 February 2022, 11:27 »
Hi All
Considering fitting a tracker to my 7.5 but I don't know anything about them as such.  There seems to be higher end ones and then cheaper DIY type ones.  Any recommendations and/or pro's and con's?
Offline Adam T7
Re: Tracker
« Reply #1 on: 08 February 2022, 12:00 »
I use a Global Telemetrics Tracker and immobiliser, been using them for 12 years now. Current version (Trident CAT 6) also allows me to immobilise the car from anywhere with my phone.
Offline P6GTD
Re: Tracker
« Reply #2 on: 08 February 2022, 12:06 »
If you just need a basic car location function with movement warnings then that is part of the VW We Connect app that is available FOC with the 7.5.
There are many on this forum who hate We Connect but for my needs it is ideal used in connection with my iPhone.
But maybe I am missing some key flaw in being able to locate my car using this facility?
Offline Adam T7
Re: Tracker
« Reply #3 on: 08 February 2022, 12:59 »
WeConnect on my phone does tell me where the car is but unless I’m missing a trick, you don’t get a pro-active call if it’s moved not under its own power / battery disabled etc. and I’m pretty sure VW won’t liaise either Police. I do like the immobilisation facility, takes less than a minute to set up / re- mobilise.
Offline P6GTD
Re: Tracker
« Reply #4 on: 08 February 2022, 13:27 »
Ah, ok Adam.
I do get a pro active text as soon as the alarm system detects movement or if the alarm is set off.
I realise the App is not as function rich as an independent tracker but maybe for many, such as myself, living and parking in “relatively low car crime” areas, it’s probably enough.
I might have a different view if I had a Golf R or S4 which generally seem to be preferred as theft targets.
In summary, I’m pretty content with the protection offered by the App.
Offline Adam T7
Re: Tracker
« Reply #5 on: 08 February 2022, 13:32 »
Ah, ok Adam.
Car crime in South Manchester is horrible, hence immobiliser, tracker, Disklock and drive security post. I didn’t know WeConnect sent a text if the alarm goes off? - I’ll have a play a bit later.👍
Offline P6GTD
Re: Tracker
« Reply #6 on: 08 February 2022, 16:54 »
Adam…..I’m pretty sure I got a text and an e mail when the alarm was triggered. And of course the alarm is sensitive to relatively small movements of the car. So if someone tries to lift the car or jack it whilst locked the alarm will go off.
I think the other stuff re car and driving information on We Connect is pretty good as well but maybe I’m easily pleased and not very technical.
Offline Fisher2022
Re: Tracker
« Reply #7 on: 08 February 2022, 17:13 »
I didn't even know the We Connect thing existed.  Here it says notifications are only enabled if you have the anti theft alarm, which presumably the GTI has?
https://www.volkswagen.co.uk/en/connected-services/we-connect/features/safety.html
Offline P6GTD
Re: Tracker
« Reply #8 on: 08 February 2022, 17:17 »
Get the We Connect App, go into settings, then notifications and click on vehicle theft alarm to activate.
Offline Adam T7
Re: Tracker
« Reply #9 on: 08 February 2022, 17:41 »
Cheers - mine was on anyway😄
