Author Topic: BBC Radio 1 DAB reception awful  (Read 5144 times)
Offline sjw
« on: 20 January 2022, 17:02 »
Hi all,
For the last few months, my DAB reception on BBC Radio 1 (and only Radio 1) has been awful, in areas where it used to be fine. I live around Cambridge and most of the issues I have are on the major roads around the city, A14, M11 etc. It'll drop to FM constantly - if I tap the station logo again, it'll switch back to DAB, but not always for very long.
Has anyone else ever had this before, where just a single station keeps dropping to FM? I've tried rescanning etc, but not sure what else to do. Is there a full reset or anything?
Offline itavaltalainen
Re: BBC Radio 1 DAB reception awful
« Reply #1 on: 23 January 2022, 15:31 »
Got any faults showing on a scan of module 5F?
Could be a failing aerial, amp or wiring.
Offline Vwjap
« Reply #2 on: 23 January 2022, 16:16 »
Don’t the aerials get rusty (or corroded from water ingress) under the trim in the boot area?
Offline mcmaddy
« Reply #3 on: 24 January 2022, 08:54 »
If it's just on radio 1 it's hardly likely to be the aerial. If it was all dab stations then maybe it would be a faulty aerial.
Offline SRGTD
« Reply #4 on: 24 January 2022, 10:11 »
I get DAB reception dropping off to FM on the radio station I listen to - always in the same locations on one of my regular routes. It did it in my previous car too, so I put it down to just poor signal quality at those locations. If I don’t tap the radio station logo on the infotainment screen, DAB reception will come back again of its own accord - usually within a mile’s driving when (presumably) I’ve moved into an area with better DAB signal quality.
Gone but not forgotten;
2016 Polo GTI; Blue Silk
Offline sjw
« Reply #5 on: 24 January 2022, 10:39 »
That's what I thought, but I'm going to scan it anyway.
Righto, but this didn't happen before and other cars with DAB radio don't suffer in the same areas.
Offline martin998877
« Reply #6 on: 24 January 2022, 20:02 »
I've had various VW Golfs with DAB - all have much worse reception on DAB than other makes I've had, it's a VW weakness I think.
Golf GTi Mark 7 owner
Offline Lordie
« Reply #7 on: 26 January 2022, 21:44 »
Random slightly related question. I have a varied music taste, and I can't see 'Kerrang Radio' in DAB stations list even though it is a DAB station and I've seen it in listed other peoples vehicles. Anyone know why?  :shocked:
Offline jv
  • Administrator
« Reply #8 on: 26 January 2022, 22:14 »
Good taste filter is enabled?
Buy site stuff!
GolfGTI.co.uk - merchandise
Support the forum charity!
Offline Paul_GTI
« Reply #9 on: 04 February 2022, 07:21 »
I saw something similar with other stations dropping to FM, but if I turn off the DAB > FM option in settings DAB doesn't drop so it seems like it is being overly sensitive.
Do you have a dashcam hardwired or any USB cables connected?
