Author Topic: What are your perfect EQ Settings?  (Read 5011 times)
Offline Brenbo
« on: 15 January 2022, 12:03 »
I currently own a Golf R MK8 with Harmon Kardon Sound System.  What are your perfect EQ settings for getting the best sound out of the Harmon Kardon sound system?
As a side note, I previously had a Golf R MK7 and the dynaudio system was audibly different to the Harmon Kardon system i now have in the MK8 Golf, both are good but i wonder if at present i prefer the dynaudio system once i setup the EQ settings...
« Last Edit: 15 January 2022, 13:22 by Brenbo »
Offline fredgroves
Re: What are your perfect EQ Settings?
« Reply #1 on: 15 January 2022, 14:12 »
Depends what you like to listen to, although with the "mood" settings I find I can easily switch between different types of audio without messing with the eq.
Might have been nice if there were instructions for it but neither vw nor hk will provide any...
The only thing I can say is that I've turned the surround totally off as it makes everything sound weird.
