Author Topic: SFD capability now added to OBD Eleven app  (Read 33499 times)
Offline fredgroves
Re: SFD capability now added to OBD Eleven app
« Reply #20 on: 14 November 2021, 13:25 »
This is what you do
After you've done it, reboot the infotainment system. Then it's accessible using the view button on the steering wheel... Cycle through to find it.
Offline Dave1rs
« Reply #21 on: 14 November 2021, 13:54 »
This is what you do
That might as well be in Russian 😂,just got obd delivered today,but guess I will have to do a lot of research of how to change things.
Offline Dave1rs
« Reply #22 on: 14 November 2021, 17:50 »
Really want the map on my dash ,but got absolutely no idea what I’m doing.
Although while messing around I have enabled a new display that I didn’t have before :smiley:
Offline bjbanny
« Reply #23 on: 14 November 2021, 19:52 »
thats a nice find. it's the Golf R display.
ordered on 30/09/2020
GTI, Pure White, Business Premium Pack, Fog light, Tinted side & rear windows,   "Richmond" alloy wheels 18, Belmont winter wheels,  IQ.LIGHT  LED Metrix, pick up Autostadt Wolfsburg.
Offline sevencrafts
« Reply #24 on: 19 November 2021, 03:10 »
This is excellent news: soundaktor here I come  :smiley:
Current: mk8 GTI - dsg - dcc - Stormtrooper White 🥰
                          - Bola XTR in storage until the spring
Previous: Leon FRd SC - manual - blue - boring 😒
                Polo GTI (6c) - manual - 3 door - white - 😍
Offline Dave1rs
« Reply #25 on: 22 November 2021, 16:22 »
Finally worked out how to add the sat nav to my dash,also have set lane assist to memory so it stays off.
Offline dubber36
« Reply #26 on: 22 November 2021, 16:36 »
What's less safe abour rear DRL activation as I have this activated and struggle to understand why its not standard?
In daylight, front DRLs make a vehicle coming towards you more noticable. You don't need to be made aware of a vehicle moving away from you by the illumination of tail lights, as the hazard is, errrr, moving away.
If light levels are low enough that visibility from behind could be compromised then auto lights or the headlight switch will take care of that.
The only thing that rear DRLs will do is protect the stupid. You know, the people you see driving in the rain/fog/dark with DRLs and no tail lights. The issue here isn't the lack of rear Daytime Running Lights it's some peoples inability to know how and when to use there vehicles lights properly.
Offline fredgroves
« Reply #27 on: 22 November 2021, 16:52 »
Well done!
Its a lot nicer now with both of those fixed isn't it!
Offline Dave1rs
« Reply #28 on: 22 November 2021, 17:15 »
Definitely,they are the only things that really annoyed me....touchwood all is fine now as I actually have no errors at all.
Offline Dave1rs
« Reply #29 on: 22 November 2021, 18:50 »
This is how I changed things to get the maps on the dash, used obd eleven and an iPhone.
Turn off sfd for the 5F unit first
To activate and to view maps on cluster ,you go into adaptions on the 5F control unit and under dashboard display configuration the settings should be as followed…
Navigation map transmission mode - IP Streaming
Navigation map compression mode - H264
Navigation map resolution - 1
Crossroad detail map transmission mode - Off
Crossroad detail map resolution - 0
Cover art - Bap
Station art - Bap
Call Picture - Bap
Dynamic icon -off
Ability switch nav maps - No
Make sure hood is open when writing to car
Once complete you should now have map cluster option on map (bottom left circle with 3 lines) may be greyed out at first and unable to select but do the below if you have this issue.
*you may need to reset infotainment system after by long pressing on/off button for 20 seconds to reset infotainment system.
« Last Edit: 27 December 2021, 07:39 by Dave1rs »
