Author Topic: Mk7.5 GTI wheel arch trim  (Read 3409 times)
Offline daviegsxr
« on: 09 November 2021, 17:18 »
Hi, I have a mk8 GTD which has the wheel arch trim.  Does anyone know if these trims will fit a mk7.5 GTI or if the same/similar is available. Thanks.
Offline willni
Re: Mk7.5 GTI wheel arch trim
« Reply #1 on: 09 November 2021, 22:18 »
Yes they will fit
Offline daviegsxr
« Reply #2 on: 12 November 2021, 19:43 »
Hi, just wondered if the front one would fit also and have you ever fitted them to a mk7.5 and if it is easy enough.
Thanks.
David.
Offline willni
« Reply #3 on: 14 November 2021, 12:37 »
Thanks.
David.
I have the rears up for sale on the classified section at the minute, they're held on by 3m tape so they will fit anything you want really if you introduce a heat gun. The wheel arches are fairly similar between the 7.5 and 8 so will fit.
