Author Topic: AFS Cornering Error - Persists even after new bulbs, help!  (Read 8509 times)
Offline ProtoCulture
I was going to tack on to one of the other threads on the same subject that I came across via Google but thought I'd start a new one, so here goes...
I had the AFS error come up on the dash on Sunday afternoon, I've changed the bulbs (Philips WhiteVision ultra H7) and its made no difference at all.
So, here's where I'm at....
- The nearside headlight is very wet inside, lots of condensation, as in full on big drops of water on the inside of the cover not just a bit of misting, especially at the front and round the indicator. I know this is acceptable to a degree but pretty sure this is excessive, and its only been an issue for the last week or two.
- The nearside cornering light stays on all the time. Offside never works despite being a new good bulb.
- The headlights don't auto level when you start the engine and were pointing very low and a little bossed eyed.
- Today for the first time the error cleared itself and they levelled up to a more normal angle, but then the error came back a few seconds later, thankfully the lights stayed at a decent level and not too low.
Before I book it into VW anything else I should check/try? Fuses?
I'm assume its something to do with the water ingress and I'm expecting a sensor or maybe even a new headlight?  :undecided:
I have a cheap OBD scanner and used ELM Car Scanner to read the codes, here's the output (I don't really know what I'm looking at) but I do see references to the headlights, I'm assuming they mean its going to be expensive! Although I've only had it for 3 months and it was VW approved used from a dealer, so I wonder if it would be covered under the warranty?
Any advise would be great, thanks.
Code: [Select]
Car Scanner ELM OBD2
DTC report
Selected brand: Volkswagen
VIN:
============1==============
10657
Raw code: 0029A1
ECU: 02. Transmission control unit
Status: Test failed (current drive cycle)
Volkswagen: P072600: Engine Speed Inp.Circ.
Range/Performance
Volkswagen: RPM Signal from ECU  P0726 00 - Implausible Signal
============2==============
10763
Raw code: 002A0B
Volkswagen: P173400: Starter release from the selector lever sensor system
============3==============
21406
Raw code: 00539E
ECU: 01. Engine control unit[Archive (inactive)]
Status: Test failed since last DTC clear, Test not completed during this operation cycle
Status bits: 1
Priority: 2
Frequency: 1
Unlearning index: 255
Odometer: 74333 km
Date, time: 2021.10.06 10:02:36
============4==============
5276144
Raw code: 5081F0
ECU: 55. Headlights corrector
Status: Test failed, Confirmed, Warning indicator requested
Volkswagen: C1081F0: Left headlamp power output stage
not coded
============5==============
5276400
Raw code: 5082F0
ECU: 55. Headlights corrector[Archive (inactive)]
Status: Confirmed
Volkswagen: C1082F0: Right headlamp power output stage
not coded
Status bits: 1
Priority: 2
Frequency: 1
Unlearning index: 184
Odometer: 74800 km
Date, time: 2021.10.31 14:38:01
============6==============
13678592
Raw code: D0B800
Status: Confirmed
Volkswagen: U10B800: Local data bus
Faulty
Status bits: 1
Priority: 2
Frequency: 3
Unlearning index: 183
Odometer: 74799 km
Date, time: 2021.10.31 13:04:41
============7==============
13679104
Raw code: D0BA00
Status: Confirmed
Status bits: 1
Priority: 2
Frequency: 71
Unlearning index: 186
Odometer: 74772 km
Date, time: 2021.10.31 12:36:30
============8==============
5275953
Raw code: 508131
Volkswagen: C108131: Left headlamp power output stage
No signal
Status bits: 1
Priority: 6
Frequency: 66
Unlearning index: 147
Odometer: 74772 km
Date, time: 2021.10.31 13:33:30
============9==============
5276209
Raw code: 508231
Status: Confirmed
Volkswagen: C108231: Right headlamp power output stage
No signal
Status bits: 1
Priority: 6
Frequency: 3
Odometer: 74773 km
Date, time: 2021.10.31 12:37:46
============10==============
5279506
Raw code: 508F12
Status: Confirmed
Volkswagen: C108F12: Left swivel module position sensor feed voltage
Short circuit to B
Status bits: 1
Priority: 2
Frequency: 1
Unlearning index: 182
Odometer: 74772 km
Date, time: 2021.10.31 13:33:58
« Last Edit: 02 November 2021, 22:48 by ProtoCulture »
2016 Tornado Red GTI PP, DSG, Pro Nav, Dynaudio, Park Assist & Camera.
Mods: Revo Stage 1 ECU & TCU remap. Racingline R600 with Inlet pipe, turbo elbow and muffler delete. Clubsport S backbox. Eibach lowering springs. VBT Hooked discs and Racingline RP700 pads, braided lines and RBF660 fluid.
Protrack One wheels (18x8, ET45) 12mm spacer on rear.
Geo by Swift Performance
Offline Agreeable Slick
  • Unit
Re: AFS Cornering Error - Persists even after new bulbs, help!
« Reply #1 on: 03 November 2021, 15:11 »
If it is still under the approved warranty then I would be taking it back immediately and asking them to fix it. There is a myriad of possible reasons it could be happening, but as stated, you have a warranty so make the most of it whilst you still can.
IMO - If the car wasn't covered then we could start trouble shooting but for now it isn't worth getting stressed over.
« Reply #2 on: 03 November 2021, 19:17 »
Hi, cheers for the reply.
Oh I intend to, just crazy busy with work and waiting for a call back from the local dealer. I bought it from a dealer who is about 60 miles away.
« Last Edit: 05 November 2021, 23:08 by ProtoCulture »
« Reply #3 on: 05 November 2021, 23:09 »
Booked in for next Friday, earliest appointment they had.
Offline JMS
« Reply #4 on: 07 November 2021, 19:26 »
Just be careful as some warranties won’t cover water leaks.
Speaking from experience with the wife’s Volvo
Previous Dubs now sold:
- Manual Mk7 CSG PP, stg1, RS3 bushes, 26mm RARB & a lot of carnauba.
- DSG mkV R32, black with even more carnauba
- Manual Corrado VR6, dragon green
- Manual Polo G40 - Tornado red, Jabbasport ported charger
- Mk2 Big Bumper 8v GTI, Calypso blue
« Reply #5 on: 17 November 2021, 22:21 »
Got a call yesterday, they are in the process of replacing the nearside headlight and both control units for the headlights? All fully under warranty.
Fingers crossed I can pick it up tomorrow!
« Last Edit: 17 November 2021, 22:25 by ProtoCulture »
Offline joe6
« Reply #6 on: 18 November 2021, 11:03 »
That sounds like a good result. Any idea how the water got into the headlight?
« Reply #7 on: 18 November 2021, 11:11 »
No idea! But I intend to ask the question when I pick the car up. Only had the thing less than 3 months so could have been something that was only an issue in the cooler months....
« Reply #8 on: 19 November 2021, 21:51 »
Got the car back this afternoon. New nearside headlight and power module as the old one was corroded apparently.
Either way, all done under warranty, bill he gave me said 890 quid! God bless warranty!
Offline Finglonga
« Reply #9 on: 20 November 2021, 14:21 »
Did you have trouble understanding him? I just read the same elsewhere. :grin:
