Author Topic: Autohold not releasing  (Read 1768 times)
Offline Rab_m_2
« on: 02 November 2021, 18:12 »
I've had a search but I can't see anything specific to my issue.
When I stop at lights etc and the auto hold activates, I've had to recently give it alot more revs to make it release and it does so with a sudden lunge forward due to the high revs.
I tried it with just the clutch and no accelerator, which used to work, but the car was nearly stalling before it finally lunged forward.
Has anyone got any ideas?
Offline fredgroves
Re: Autohold not releasing
« Reply #1 on: 02 November 2021, 19:00 »
I think there is a sensor that causes this? Clutch position?
Offline itavaltalainen
« Reply #2 on: 02 November 2021, 19:36 »
My manual mk7 never released on clutch only.
Always needed a dab on the throttle while getting the clutch up.
As for the 2 DSGs (ok one is a Leon) a dab on the throttle with the engine running and it would gently set off.
