Author Topic: 1st Mk6  (Read 6191 times)
Offline BUTSY GTI
1st Mk6
« on: 30 October 2021, 21:08 »
Been a while since I've been on but purchased my 1st Mk6 recently so scanning here on the forum for useful info.
2009 gti with 83k on the clock and FSH. Good tight driving car so far, plenty of poke so far so good. See a few posts else where regarding cam chain tensioner, when is good to get it checked mileage wise?
« Last Edit: 18 November 2021, 17:18 by BUTSY GTI »
Offline joe6
Re: 1st Mk6
« Reply #1 on: 30 October 2021, 21:51 »
The car looks in good condition. Hope you enjoy it. My 2010 has about the same mileage. If you have a full history of paperwork and invoices you should be able to check if the tensioner has already been changed. It is a sale point so the invoice will have been kept. The tensioner can only be checked visually through a small plug in the timing chain cover and is almost impossible to reach and needs a mirror to see the tensioner.  You have the first version of tensioner - there were three versions eventually before VW got the problem sorted. There is not any guidance about timing for checking and changing the tensioner and I think the time it lasts depends on how the car has been treated. The tensioner thread on this forum shows there is no mileage when it can fail. The only real symptom is a rattle at start-up and not always obvious as the injectors are quite noisy. If you need to change the tensioner it is worth looking to change chains, guides etc.
The handbook says to check the chains at 120k miles. For peace of mind I would get the timing checked fairly quickly. If you have VCDS or know someone with it you can check the timing or get a vw independent garage to do it but check costs first. This will give you some idea of any chain stretch and possibly tensioner condition..
Offline BUTSY GTI
Re: 1st Mk6
« Reply #2 on: 30 October 2021, 22:11 »
Fully stamped book with the garages it's been to but no paper work so hard to say, has a 6 month warranty so will keep an ear and eye for anything unusual. And get it looked at in the new year. Yeah very clean car and can tell it's been well looked after by the previous owner.
Offline Snoopy
  • Moderator
  • Geoff.
Re: 1st Mk6
« Reply #3 on: 31 October 2021, 06:07 »
Early chains are known to stretch.
For peace of mind with 83k on I would try find someone local with vcds/vagcom to check that.
Early tensioner can fail at any milage as it was weak.
Current Garage:
35+ years of GTI ownership.
Offline BUTSY GTI
Re: 1st Mk6
« Reply #4 on: 31 October 2021, 10:39 »
Theres a vw guy not far from me with that setup, I'll drop it up in the coming weeks and get it checked out for peace of mind
Offline roblyt
Re: 1st Mk6
« Reply #5 on: 31 October 2021, 16:35 »
the tensioner on my 09 gti failed at 50 odd k miles resulting in knackered engine so i would get it checked asap to be honest
when i had my engine rebuilt i had the latest version of the tensioner fitted so might be worth getting it changed if it hasnt been already for piece of mind
Offline Boltz
Re: 1st Mk6
« Reply #6 on: 31 October 2021, 17:28 »
Am I correct in saying that the problematic timing chain tensioners were stopped in May 2010 and a revised tensioner fitted on cars produced from this date.
Current 2010 5dr Manual GTI Carbon Steel Grey
Previous Golfs 2012 5dr Manual Edition 35 Black, 2007 5dr Manual Edition 30 Tornado Red
2001 3dr V6 4motion Reflex Silver
2004 5dr GTI Oceanic Green
Offline SRGTD
Re: 1st Mk6
« Reply #7 on: 31 October 2021, 17:44 »
There were three revisions; dates of the revisions are listed at the foot of reply #4 in the ‘sticky’ that’s pinned at the top of the forum board - link to the ‘sticky’ below;
https://www.golfgtiforum.co.uk/index.php?topic=262793.0
Gone but not forgotten;
2016 Polo GTI; Blue Silk
