Author Topic: Mk8 Clubsport Squeaking/Creaking noise front right driver side  (Read 70479 times)
Offline Beebopper
Re: Mk8 Clubsport Squeaking/Creaking noise front right driver side
« Reply #60 on: 29 January 2025, 13:05 »
Is the TPI / boot replacement a warranty fix or not covered under VW's warranty?
Mine was all done under warranty (5 visits)
Noticed they put missing engine cover on as well
Had courtesy car each time
Ok that's good to know thanks, mines just gone in for some suspension noises and I suspect it is this and maybe the lower arm bushes too. Hoping it is all covered under warranty, sounds like it should be.
Prior - MK2 GTi Big Bumper in White
Current - MK8 GTi Clubsport in Moonstone Grey
(Plus Many other non-Golf hot-hatches in-between!)
Offline GTI9
Hi All, I’ve found this article based on an issue I’m facing with my 8.5 Clubsport. It’s creaking and the dealerships can’t find a fault despite me taking a technician on a test drive. Can I ask which dealerships you used to resolve the issue as my local VW aren’t any help. Thanks.
