Author Topic: Mk8 Clubsport Squeaking/Creaking noise front right driver side  (Read 70511 times)
Offline Megy_CS
I had similar sounding noises in my CS and they replaced the NSF top mount and OSF shock strut and now no further noise.
Further to my earlier post, I have had both front top mounts replaced plus both shocks and the noise has come back and is going in again tomorrow for further investigations
Offline fredgroves
My GTI does it - sounds like the front suspension is knackered... you get a creaky groaning noise as the suspension unloads.
They've not attempted to fix it, just told me they couldn't hear the problem... despite me telling them how to reproduce it.
Offline Sniffer
Picked up my car this morning and, I think, the noise has gone. It does seem that it's a common issue though, because there's a TPI (2064607/2) quoted on the warranty paperwork. Basically, the dealers have dismantled and rebuilt my car's front suspension.
1981-84 Mk1 Golf GTI (Black);
1984-86 Mk 2 Golf GTI (White);
1986-88 Scirocco GTX (Graphite)
Gap - The Sensible Years (Mostly)
2016 Mk 7 Golf GT TDI; (Silver)
2018 Mk7.5 GTI DSG (Red)
2020 - Mk 8 GTI DSG (White)
2021 - Mk 8 GTI DSG (Pearl Black),19"Adelaides
2024 - Mk 8 GTI DSG (Kings Red), 19" Adelaides
2026 - Mk 8.5 GTI DSG (Dolphin Grey) 19" Estorils, DCC, Exterior Styling Pack, Area View Camera, Winter Pk etc - May 2026
Offline Rudedog
I had two recent creaks from the front suspension.... the dealers used a TPI to replace/grease the main front sub-frame bolts which fixed the issue I had when braking/turning in.... the other parking related creak they couldn't find/fix.
Offline PammyGTI
I had the same issue when I bought my Mk8 GTI in Nov 21, started to make squeaking/creaking noises around the front every time I went over a bump,  took it into VW & the technician replaced the cv boots,  runs like a dream now, no more squeaks !
If it’s still under warranty get them changed!
Offline Brocky_
Thanks for the TPI info, Sniffer. Mine had the 'better grease' as they called it done around six months ago and it worked initially but the issue came back after about three months. I'm due in for a service in the next few weeks and I've put it on as something to be investigated. I'll pass on the TPI info when I drop it off.
Mk.8 GTI ClubSport
Offline Sniffer
Yes, I had the same interim (lithium grease) fix applied in October.  It only masked the problem for a few months. Good luck!
Offline Brocky_
Mine was in for it's first service at Inchcape today.  I completely forgot to give them the TPI info that Sniffer posted but I listed it for investigation and they've come back with...
"Carried out investigation into creaky suspension and confirmed fault with gaiters on shockers sized from following a test plan.  Removed and refitted trim correctly and all tested ok."
From that, I'm not entirely certain what they've done.  It's not the clearest job description in the world, is it?
Also had the engine cover off and can confirm that there's no noticeable extra noise.  I asked if there was a replacement in the pipeline and they said that they didn't know.
Also found out that I'm not too far away from needing new front tires.  I haven't rotated them in the time I have had the car, admittedly, but still didn't expect to be changing them (Goodyears) at 19k miles, to be honest.  Frequent tyre changes come with the territory of being a GTI owner, I guess.  I could get away with swapping the fronts and rears and will get another couple of months out of them but I have been deliberating sticking some PS4Ss on, so not sure it's worth the hassle.
Mk.8 GTI ClubSport
Offline SCourtney
That is what they did to mine about 2 weeks ago, and so far so good.
Current: MK 8 GTI Deep Black
Gone: MK 7.5 GTI red
Gone: MK 5 GTI red
Offline fredgroves
Not changing the fronts at 19k?
Do you drive like miss daisy?
About 14ish for fronts normally on my gtd's, my gti had an early bath at 11k, but probably wouldnt have made more than 13k
