Author Topic: Replacement clutch costs fitted?  (Read 5373 times)
Offline joe6
« on: 29 September 2021, 18:02 »
Just been quoted £1100 to replace dmf, clutch plate and release bearing. All oem parts. Does this seem reasonable?
Offline doberman19
Re: Replacement clutch costs fitted?
« Reply #1 on: 29 September 2021, 19:52 »
It does sound reasonable if the DMF is also being replaced, and it's VW that's doing the job,
Perhaps you should shop around, but it isn't a cheap job, I bought a complete clutch a couple of years ago and that was the best part of 500 quid, and then you have to find someone to fit it.
Offline Borbus
« Reply #2 on: 08 October 2021, 09:29 »
If you're in the right area and have a driveway I can recommend this mobile mechanic: https://www.williamsmobileclutch.co.uk/ He has a Youtube channel with all his work here: https://www.youtube.com/channel/UCLFbTVnY1UsqChkPBs7zdWg
I paid about £750 and he did the whole job in less than a day. Got full Sachs kit, both clutch kit and DMF. A garage/stealers would probably keep your car for multiple days and tut a lot about doing a clutch.
« Last Edit: 08 October 2021, 09:33 by Borbus »
2010 Mk6 GTI
Offline joe6
« Reply #3 on: 08 October 2021, 19:31 »
Thanks for the heads up Borbus. Looking at locations where they have fitted clutches, I may be a bit too far north. Might have to go to my local vw independent who has a good reputation cheaper than stealers but not that cheap.
