Golf mk7
Jimble
20k miles wheel bearing?
Topic: 20k miles wheel bearing? (Read 2663 times)
Catnapper
GTI forum regular
01 September 2021, 12:26 »
Swinging the car around in a car park noticed a noise which suspiciously sounds like a wheel bearing.
Car's a 2017 with 20k miles.
Anyone else experienced this and what's the chances of getting it done under extended warranty
MK7.5 Indium Grey 19" Brescia Alloys
willni
Re: 20k miles wheel bearing?
01 September 2021, 12:40 »
Jack it up and spin the wheels see if you can work out which one it is.
Should be fairly easily done under warranty, not really a thing that could be argued.
Follow my 7.5 build on the forum
https://www.golfgtiforum.co.uk/index.php?topic=287596.msg2638666#new
or on Instagram
https://www.instagram.com/willy_gti7.5pp/
Watts
Forum addict
01 September 2021, 12:43 »
I had one replaced on my last GTI at around 10k miles, very likely pothole damage.
Previously:
Guzzle
01 September 2021, 19:14 »
Check the tyre to make sure you don't have something stuck in it.
7.5 GTD
Finglonga
05 September 2021, 14:06 »
Worn rear tyres are very noisy on the MK7 and sound like wheel bearings are on the way out.
Catnapper
GTI forum regular
06 September 2021, 10:31 »
New rear discs n pads on the way so will look into when changing them.
Tyres are virtually brand new.
Catnapper
GTI forum regular
Reply #6 on:
13 September 2021, 12:51 »
Update:
Replaced rear discs & pads and now all seems good.
Discs weren't as bad as I thought just worn unevenly pads had 50% left.
So fingers crossed it was maybe just that
Golf mk7
Jimble
