Author Topic: mk7 GT Clubsport, clutch pedal issue..helpplease  (Read 1833 times)
Offline NK
« on: 30 August 2021, 22:36 »
Clutch is intermittently notch with a click on depressing pedal, more likely if haven't changed gear for a while. (sometimes hear clicks turning around the corner or going over bumps).... clutch, flywheel, slave cylinder and master cylinder have all been changed....ps in between these episodes the clutch pedal is absolutely fine!
all the bits were changed as the clutch pedal stopped coming up  (delayed after halfway) with worse itchiness to now
grateful if  anyone has any ideas?
